Couple of notes on getting a tailgate off by yourself.
Open and prop, I used my jack
Left disconnect. Big plug under trim then work plug through the grommet. You have to remove plastic clip and perhaps cut the gasket
Right disconnect. Another clip, gasket , and pop off the washer hose inside , pull hose though
Now remove the four outboard facing T40 bolts and let the tailgate loose.
It’s heavy but not crazy to handle with one person , maybe 35 kg or so
P80 tailgate removal solo
- Has thanked: 1500 times
- Been thanked: 3812 times
