1999 S70 GLT
When I bought this car, they had switched the seats and the SRS light has been on. I now have VIDA/DICE. I connected and selected Erase SRS, however the light is still on. All connections are there and solid. DICE is showing no fault codes
Thoughts?
SRS Question
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 47 times
- Been thanked: 44 times
SRS Question
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
- misha
- Has thanked: 152 times
- Been thanked: 402 times
You need to read the codes first...then clear them.
If problem isn't solved...srs light and codes will appear again.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Grantkat
I am not seeing any codes. When i run diagnostics it comes back and says no codes.
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- Grantkat
i went out and ran it again.
I have an EVAP DTC, (which I already knew) but no other codes. Ran an erase. SRS light stays on, but no codes.
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- Has thanked: 1851 times
- Been thanked: 1712 times
That is strange that the light is on and no codes. I can only think someone has either fitted something that is not compatible, there is a connector that is corroded or dirty, or something is actually bad. But I would expect all to throw a code though.
- Grantkat
the connectors all look clean - like brand new type clean. I can t figure it out. It has to have something to do with the seats being switched.
I will try and take a couple of pictures of the connections under the seats and put them up here.
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 94 times
- Been thanked: 39 times
Had a similar problem on my 2000 S70 GLT SE - SRS light on and code would not clear. What worked for me was to turn the ignition key to the second position and then back off at a comfortable, steady speed 10 times and then leave it in position 2 and clear the codes.. This was with a Youcanic scanner.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- Grantkat
here is a shot of both front seats drivers first and then passenger
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- Grantkat
sorry - here is a better one of the driver side - i selected the wrong one...
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
jmartin919
Did you try the key trick?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
