SRS Question
Grantkat
Year and Model: 1999 s70 GLT
Has thanked: 47 times
Been thanked: 44 times
SRS Question
Post by Grantkat »
1999 S70 GLT
When I bought this car, they had switched the seats and the SRS light has been on. I now have VIDA/DICE. I connected and selected Erase SRS, however the light is still on. All connections are there and solid. DICE is showing no fault codes
Thoughts?
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
You need to read the codes first...then clear them.
If problem isn't solved...srs light and codes will appear again.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Grantkat
Post by Grantkat »
I am not seeing any codes. When i run diagnostics it comes back and says no codes.
1999 S70 GLT ~193k
2014D VIDA/DICE
Grantkat
Post by Grantkat »
i went out and ran it again.
I have an EVAP DTC, (which I already knew) but no other codes. Ran an erase. SRS light stays on, but no codes.
1999 S70 GLT ~193k
2014D VIDA/DICE
Has thanked: 1836 times
Been thanked: 1709 times
That is strange that the light is on and no codes. I can only think someone has either fitted something that is not compatible, there is a connector that is corroded or dirty, or something is actually bad. But I would expect all to throw a code though.
Grantkat
Post by Grantkat »
the connectors all look clean - like brand new type clean. I can t figure it out. It has to have something to do with the seats being switched.
I will try and take a couple of pictures of the connections under the seats and put them up here.
1999 S70 GLT ~193k
2014D VIDA/DICE
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 94 times
Been thanked: 39 times
Post by jmartin919 »
Had a similar problem on my 2000 S70 GLT SE - SRS light on and code would not clear. What worked for me was to turn the ignition key to the second position and then back off at a comfortable, steady speed 10 times and then leave it in position 2 and clear the codes.. This was with a Youcanic scanner.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
Grantkat
Post by Grantkat »
here is a shot of both front seats drivers first and then passenger
1999 S70 GLT ~193k
2014D VIDA/DICE
Grantkat
Post by Grantkat »
sorry - here is a better one of the driver side - i selected the wrong one...
1999 S70 GLT ~193k
2014D VIDA/DICE
jmartin919
Did you try the key trick?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
