Upgraded from ID1050xds to ID1300xds injectors and from the DW300c to the DW400 pump.
Everything should be back from Cerakote next week. I expect to make leaps in progress, if not nearly finish up
after the parts are in hand. Heat shielding for the fuel lines, turbo coolant lines, and turbo oil feed line will be ordered tomorrow as will the upgraded pump. ID1300s are in hand. Will be able to wrap up the Setrab oil cooler and Improved Racing inline thermostat. Couple of odds and ends fittings, bolts, hose clamps and cleaning.
SMöR öL: C30 Build Topic is solved
precisionguesswork
- Year and Model: 2008 C30
- Has thanked: 12 times
- Been thanked: 16 times
precisionguesswork
Need to weld a cast 90 onto the compressor outlet to clear the power steering lines. This bit will make more sense once I upload images
precisionguesswork
Picking up parts from Cerakote today..
pics to follow
pics to follow
precisionguesswork
- Has thanked: 2858 times
- Been thanked: 1332 times
Some of those pieces look like they were manufactured on the International Space Station. Just beautiful. Good thing they'll live inside a 3000-pound metal case to protect them.
precisionguesswork
Back in the shop tomorrow
precisionguesswork
precisionguesswork
Exhaust manifold is in permanently. Mocked up turbo for vac lines and next project will be, cold side, charge pipe, welding neck onto compressor outlet, and with any luck oil cooler.
precisionguesswork
precisionguesswork
Ran out of time due to remodeling my daughter's home to be ready for sale this spring. Car is back in storage until around thanksgiving.
To be continued....
To be continued....
