04 V70R M66 AWD Front Right Axle
spinard
Year and Model: '04 V70R, '16 XC70
Been thanked: 3 times
Post by spinard »
When your CV axle is made from 100% pure unobtainium, this is the last thing you want to see. Yes, this is the dreaded front right axle from an '04 V70R M66 AWD.
The only axle I could find (period) that might work is the Trakmotive VO-8041, despite unclear fitment information. I'm going to give that a try, unless someone chimes in and says I definitely should not.
The good news is that the transmission and angle gear are still in great shape (had to drop 'em to check). And the "while we're at it" list included new front subframe bushings, prop shaft front CV (torn boot), angle gear collar and seal kit, engine & transmission torque mounts all around, lower ball joints, and fluid replacements.
Appreciate everyone's crossed fingers.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
roadside repair guys in pakistan could weld that no problem.
Has thanked: 1505 times
Been thanked: 3818 times
Is that axle a tube vs solid on the R font weight reduction? I’ve never seen an axle snap like that.
Is that awd m66 ftom Canada or is it a conversion?
We didn’t get awd m66 in the States TTBOMK
Corrected
spinard
Post by spinard »
abscate wrote: 13 Apr 2025, 04:06 😀😀😀
Is that awd m66 ftom Canada or is it a conversion? We didn’t get awd m66 in the States TTBOMK
Wow, I've never heard that M66 AWD were not available in the US. Vehicle history shows its entire life in MA, PA, and OH. If it's a conversion I wouldn't know.
Yeah, the shaft is (was) a tube between the angle gear and the inner CV joint.
Break Close Up.jpg (60.27 KiB) Viewed 443 times
Maybe just the xc70 didn’t come with m66?
Has thanked: 292 times
Been thanked: 765 times
There are/were lots of P2 R cars with M66 in the US. Both S60 and V70.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Sujsage
Year and Model: 2004 S60R
Post by Sujsage »
spinard wrote: 12 Apr 2025, 17:47 The only axle I could find (period) that might work is the Trakmotive VO-8041, despite unclear fitment information. I'm going to give that a try, unless someone chimes in and says I definitely should not.
Just wanted to confirm that the VO-8041 is a perfect fit for a passenger side M66 AWD axle, I just put one in last weekend. The inner joint is a different style but the length and position of the support bearing are the same as the old stock one.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Sujsage wrote: 16 Apr 2025, 22:41 Just wanted to confirm that the VO-8041 is a perfect fit for a passenger side M66 AWD axle, I just put one in last weekend. The inner joint is a different style but the length and position of the support bearing are the same as the old stock one.
Can't find the exact picture, but Chinese axles love to do this in high power applications:
Auto-torque damping feature
Has thanked: 1850 times
Been thanked: 1710 times
Does the S60R have the same axle as the V70R? If they do then you get both with manual trans (spaceball).
I'll keep an eye out for one. There are a couple of people selling parts from broken P2 R's in the BC area of Canada on FBM.
