Has thanked: 1505 times
Been thanked: 3817 times
Always a bit scary when you see those. Kudos to tire makers for redundant redundancy
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Chuck W wrote: 31 May 2025, 22:31 Had to replace the second tire she's done this to in the past 3-4 months. :roll:
That's a thing going around. You pick it up on the street. I think it is called tire pox.
volvolugnutr
DennisCA
Year and Model: 1996 850
Been thanked: 59 times
Post by DennisCA »
Took the center console off the 850 today.
There are cracks here and there
The piece that holds the armrest has come off and has been repaired before.
Here it is really terrible looking as the previous owner tried to glue the leather gaiter to the gear lever.
After I removed the glue it looks better. I think I can save this center console.
Patching the cracks with epoxy
This crack is hard to see. This crack in the front I want to glue with metal epoxy and a piece of flat iron on the underside to support the whole thing. I have something called Devcon that gets very strong when it hardens.
I think the seats are going to come out too so I can get the car properly cleaned.
I've also figured out that the 850 arm rest will work in my Saab 900 too, currently building a holder for it, that's one thing I miss in that car, the nice arm rest. And the grey velour looks better than any of the leather variants out there. I've found another grey velour arm rest online so I'll be getting that one. This way I'll also get cup holders.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Huge bolt ! :)
1999 V70 GLT
MotorTheresa
Year and Model: V70 1998 B5252F/S MT
Has thanked: 31 times
Been thanked: 11 times
Post by MotorTheresa »
Today was new parking brake cables day.
E-brakes performed like rubbish and I could already see one cable showing internal rust through the sleeve. This is an issue for MOT/TÜV certification and a nuisance in general.
Nice makeshift washer :/
Friction material gone
Cable catch ripped
Cable catch ripped
Assembled wrong way round :|
With new Volvo cables at hand and RobertDIY video on repeat I replaced the old (aftermarket) cables and refitted drums with ATE brake shoes.
Thanks Skandix for selling the bolt w/o captive washer :D
Noticed the original cable has a dirt deflector rubber the aftermarket one did not have (anymore)
I spent quite some time on both cable seats to get the rust and dirt out to make for a snug cable connection
Riveting-on the cable catch
Seated
Seated
I was really happy with the cable quality and fit. Refitted drums were a charm to adjust and now the Vehicle has its "anchor" back.
It always bothered me that the equalizer was out of balance. I noticed a washer used underneath the cable supposedly compensating a bad part fit.
Also treated me with a bright LED sofitte bulb for the trunk dome light. I love it. Day was a success.
Equalizer balanced now
Happy with the routing
Sveedy
Post by Sveedy »
^ Very clean !
1999 V70 GLT
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Bulge or Blister. Could someone have skimmed a lateral surface? What is the age (DOT Date) of the tire? Lots of tread but rubber looks weathered. Some older Falken had weak sidewalls.
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 335 times
Post by Chuck W »
MoVolvos wrote: 02 Jun 2025, 10:02 .
Oh, I know the cause. She keeps nailing potholes. Both tires had 2023 build dates and were on the car for about a year, at most.
That's dirt you see, not weathering.
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Had a loud speed related rotational noise, which i'm quite sure was a CV joint.
I wasnt financially ready to get a proper quality new shaft so went for a 25€ Meyle CV, installed on the shaft that was originally on the car (also removed because cv was tired). Quality seems ok, the boot rubber thickness seemed similar to OE. Time will tell, wont be surprised if it fails within two years but one can hope !
During my test drive I thought I had f'd up something, but no, turns out one of the rear spring perch got loose and I couldn't hear it under normal driving conditions since i'm always listening to some music :lol:
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Goupil
Post by Goupil »
Goupil wrote: 16 May 2025, 15:43
Chuck W wrote: 15 May 2025, 12:00
abscate wrote: 14 May 2025, 14:07 What do you do with an old air bag??
Really ??
I have 2 in the garage (Dr and Ps) that probably came out of my old '96 GLT. Not sure how to dispose of them, and I'm not up for a hurtful prank on anyone. I actually pondered swapping the Ds one into her car recently as I chased down the SRS code.
@Goupil Are you able to "refresh" that FP relay?
Yeah, I need to do it before the spare I installed inevitably fails :lol:
Update: I didn't. Glad i kept the bypass wire in the car :roll:
