What is leaking? 1999 volvo S70
Silentiary
Year and Model: 1999 S70
Post by Silentiary »
What is leaking?
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
Is that the driver's side or passenger's side? I'd guess coolant, but if you have an automatic transmission, it could be ATF. I don't think any of the cars have an oil cooler in the radiator.
Assuming coolant, you probably have a bad tank seal, or a cracked tank.
Probably the best thing to do, would be to borrow a coolant pressure tester from Autozone, or whatever parts store you have locally that will "rent" tools. Hopefully, they also have the adapter that will be needed to attach it, in place of the pressure cap. That will allow you to pressurize the system without the engine running, and you can look and listen for the leak.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1506 times
Been thanked: 3818 times
Passenger side.
The seal between the metal radiator and the plastic end cap is gone. They last about 150,000 miles.
Time for a new radiator. Nissens will work
deaddirewolf
Post by deaddirewolf »
My guess is radiator time. Just replaced that same radiator on my 1999 S70 with 135k. It cracked once and I patched it with some JB Weld. Held for about a month and then the whole bottom blew out. If it's leaking coolant, better replace it before it blows.
