Help with ECM 1998 V70 manual wagon
Has thanked: 1613 times
Been thanked: 4078 times
I think I have an old 1998 ECM in my stash upstate but it would be for an automatic car. I’m 99% it would start and run but would probably either CEL or TCm arrow flash if it can’t see the auto transmission
Has thanked: 2215 times
Been thanked: 1853 times
Would it even start without the PnP signal? They can be re-written as those who have done manual swaps have to do.
scot850 wrote: 06 Jul 2025, 09:20 Would it even start without the PnP signal? They can be re-written as those who have done manual swaps have to do.
I’m 99% sure it will start and run, but code.
gregoryahunter1
Year and Model: 1998 v70
Post by gregoryahunter1 »
Follow up from me (OP) - I will go through all of the suggested items with my mechanic that DO NOT have to do with the ECM tomorrow, AND I ordered a new Type R ECM from VAST as well. If it does turn out to be the computer - I will have a new one by Tuesday. If it isn't the ECM (as many of you suspect) then I get an ECM with the Type R tune: WIN WIN! Thanks again for all of your help
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
I'm pretty sure it won't.
P'n'p switch must be jumped after manual swap.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
gregoryahunter1
UPDATE: My mechanic was able to get the car started with a combination of unplugging some incorrectly connected plugs and my new ECM from Vast Tuning. So its just about ready to be driven.
Since its been sitting for years - What do yall suggest for maintenance before I drive it much - I was thinking:
-Oil Change
-Coolant flush
-Manual transmission fluid change
- new brake fluid
-look at belts
Other stuff I should do?
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
Good to hear it’s alive. You’ll really enjoy that spicier ECU once you start driving the car.
That’s a good start, keep going. Don’t just look at the belts, replace them, especially if there’s no history on them. Timing belt, water pump, idler, and tensioner should be a priority. Do the accessory belt and its tensioner as well. Spark plugs too - add coil, wires, and distributor cap/rotor if they haven’t been done recently. All the coolant hoses. Engine mounts. Suspension. Brakes. Etc
If you can’t tell when (if ever) something has last been replaced and it would leave you stranded/cause major issues if it failed, replace it.
Make sure to use only quality parts or you’ll be right back at it sooner rather than later. Use only trusted parts from FCPEuro or the Volvo dealer - no parts store/FleaBay/Scamazon/Uro/ ProParts crap.
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
