mileage : 700,000km+ / 450,000+ ( it stopped working 3 years ago, I heard its a common problem but it doesnt bother me )
Anyways, my 240's e brake kind of works, I know that it isnt adjusted right and I need to do my rear disk brake pads anyways. I was wondering what the procedure would be for tightening the e brake drum?
Would I have to remove the rotor to access the drum?
Thank you for the help
James
e brake kind of working // 87 240DL
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Another low mileage Volvo!!!
The rear brakes on the 240, and other models, incorporate the e (parking) brake. The centre of the rotor is the drum for the parking brake shoes.
To adjust the parking brake without checking for wear on the shoes would be a waste of time.
To access the brake shoes remove the centre console rear ashtray. Working through the hole loosen the parking brake cable adjusting nut until the cables are slack.
Raise and support the rear end and remove the wheels.
Remove the brake pads and calipers, without disconnecting the hydraulic line, and support the caliper out of the way.
Remove the rotor (disc).
You now have access to the parking brake shoes. If they need replacing remove the return springs and the adjuster.
If the drum is more than 0.008ins (0.2mm) out of round it must be replaced.
Apply a thin coat of heat-resistant grease to the shoe sliding surfaces and the adjuster.
Replace the drum and adjust the brakes.
Align the hole in the drum with the adjuster.
Tighten the adjuster until the drum can just be rotated by hand then back off the adjuster until the drum just rotates freely.
Install the rear wheels.
Adjust the cable until the parking brake is fully applied when the lever is pulled up 2 or 3 notches.
Replace the ashtray and lower the vehicle.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- billofdurham
You are welcome.
Thank you for the update.
Bill.
Bill.
Previously:
Previously:
- 1428 Views
Last post by pdr1966sc
- 869 Views
Last post by benpineapple
