I bought the car 2months ago, and sometimes the abs+brake light went on.
Last week i took a trip about 2hrs and was on the road when i hit a bump when all three lights came on abs ,check eng ,brakes.
When i came to a stop in went into limp mode, downshifted manualy and it worked fine. Since then took to a trans shop drove it and he said it was fine, he got these codes p0722,+p1648 does anyone know what this might be?
2000 v70 xe turbo, abs ,brake and blinking arrow,check eng
joe curtin
- Year and Model:
joe curtin
JRL
- Year and Model: Several
- Been thanked: 16 times
On a 2000 a bad ABS unit can cause the dashboard to go haywire along with t host of other functionsjoe curtin wrote:i bought the car 2months ago, and sometimes the abs+brake light went on.
last week i took a trip about 2hrs and was on the road when i hit a bump when all three lights came on abs ,check eng ,brakes . when i came to a stop in went into limp mode. downshifted manualy and itworked fine.since then took to a trans shop drove it and he said it was fine,he got these codes p0722,+p1648,does anyone know what this might be?[/img][/list][/list][/code]
Rebuild the unit now
www.modulemaster.com
joe curtin
- Year and Model:
well,b4 i changed the abs module,i took it to a mechanic who works on volvos he said it was the speed sensor,do to the codes and his test.so im waiting for the part to come inand will c what happens.
joe curtin
JRL
Also check your axles for tightness. I had one that the axle was ready to fall out, everytime I hit a bad bump, all the lights came onjoe curtin wrote:well,b4 i changed the abs module,i took it to a mechanic who works on volvos he said it was the speed sensor,do to the codes and his test.so im waiting for the part to come inand will c what happens.
gshadow325
- Year and Model:
gotta agreee with JRL on this one, repair the ABS module FIRST. I wasted $80 on a new abs sensor (that's the code that came up). Its a bad abs module.
joe curtin
- Year and Model:
i just got my car back,it was the speed sensor,and a wiring problem,it took the mechanic a few days to find it.the code po722,p1618,went with the speed sensor,the lasy code never went away, so no speedometer,so he went threw the wiring and found it. the best 300dollars i ever spent. volvo wanted 150 just to put it on the machine.
joe curtin
- 1199 Views
Last post by precopster
- 35 Replies
- 4855 Views
- 1804 Views
Last post by CDoore54
- 2303 Views
Last post by Scholz
- 12 Replies
- 1955 Views
Last post by RussB
