This car has the cold weather package which includes the headlight wipers, fog lights and traction control. I was able to verify this a while back.Chili58 wrote: ↑21 Feb 2026, 02:48 I understand you purchased a car, that had all the issues. Therefore it is good to check - at least - that the ABS control unit is a correct one; you never know, if the previous owner swapped there a wrong ABS control unit already.
The correct ABS control units are any of the following ones in case you have also TRACS : 9162675, 9140774, 8602266 ; but you should be sure about the fact, if you have TRACS or not.
But Volvo part # 9140773, 8602265 are correct ones for vehicles WITHOUT TRACS traction control. Both part numbers are identical/compatible.
It currently has a tracs ABS unit in it now
Also I mentioned before but ABS and Traction control were tested working on my test drive, Only cluster is unhappy for some reason.
Also in theory tachometer should still work even with bad or missing ABS module.
My current theory is cluster, wiring or bad connection is problem somehow, at least for the tachometer problem.
