U.S. octane requirement question
CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 328 times
Been thanked: 87 times
Post by CIK7 »
Outside the US, a different octane rating is used. For my post I'm using the US numbers.
In the manual (pic below), it shows the NA is higher compression (10.5:1) and turbo is lower compression (8.5-9.0:1). I already knew that. My understanding is that a lower compression engine can use regular 87. The higher needs 91. But either Volvo wants us to use 91 or someone has trained us to think we need to use 91 on the lower compression engines. What is it that I am missing?
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Has thanked: 1506 times
Been thanked: 3818 times
Compression ratio is the static ratio of chamber with piston down and piston up. When a turbo boosts, it pushes extra air into the cylinder and the effective pressure in the cylinder is higher? How much? I’m not sure.
I run either 91 or 94 in my turbo cars and 91 in my NA cars
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1001 times
Post by volvolugnut »
When my preferred local station stopped having premium, no ethanol fuel a couple years ago, I started using the low octane fuel. No noticeable problems.
I believe the ignition controls will adjust if knock occurs with low octane fuel.
This is on 2001 V70 T5. Also 2001 Mercedes E320.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Have been using Premium ever since it came out. Still remember using Leaded fuel especially in V8’s without CAT. The smell of muscle car exhaust 👍.
Wife noticed when I tried to save money by trying 87 and she doesn’t know anything about cars. Never had a CAT, fuel, ignition or code from potential fuel related issues.
Have 100K on a set of Iridium on the 03 Odyssey at 259K and still running smooth.
Has thanked: 1850 times
Been thanked: 1712 times
Has anyone checked their gas mileage when running regular gas? I tried it with a couple of cars that were advised to used premium gas by manufacturer's. In both cases the mileage reduced to the point where the saving made it pointless.
CIK7
Post by CIK7 »
scot850 wrote: 09 Mar 2026, 12:10 Has anyone checked their gas mileage when running regular gas? I tried it with a couple of cars that were advised to used premium gas by manufacturer's. In both cases the mileage reduced to the point where the saving made it pointless.
Maybe I'll try on the gray 850 if I get the white 850 as planned.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
MoVolvos wrote: 09 Mar 2026, 09:53 .
I had to re-read that, as at first, I interpreted CAT as Caterpillar. :o
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
Remember premium differs by US state. Here in Colorado it’s 91 octane. In lower elevations it’s 93 octane. So, another variable.
Also -> Amazon link
Here Premium is 91 which is at similar elevations to Denver. We also have 93 and 94 options, but they are not called premium,
matthew1
Site Admin
Post by matthew1 »
Interesting. I think there are some between 91 and 100, but they're very uncommon. There are one or two places in the metro area that have 100 octane "race gas" and it's pretty darn expensive.
Here's more octane talk: https://www.matthewsvolvosite.com/volvo ... iscussion/
Also -> Amazon link
