Off we go....
15 minutes to strip down
19mm lugs
10 mm rotor screw
13 mm caliper bolts
punch and hammer for pins
30 seconds MAPP - then an 11mm flare wrench to loosen hard line
Sledge hammer on rotor
1999 V70 T5 M56 seized rear right caliper... brake job 31262626/31262480 31262622/ 3(now turned into a bad parts thread)
- Been thanked: 4068 times
- 6058B356-E223-4718-A0B9-578DD1CE29CD_1_105_c.jpeg (79.42 KiB) Viewed 921 times
- 7DAC9B84-86A9-45BA-98A3-6E4B826BAAFC_1_105_c.jpeg (67.14 KiB) Viewed 921 times
- 5B6FDFA8-D264-4C22-8274-8D3070415B90_4_5005_c.jpeg (48.4 KiB) Viewed 921 times
- 86D41966-8518-4C2C-A315-5CB86FC3AFF3_4_5005_c.jpeg (41.77 KiB) Viewed 921 times
- Has thanked: 2202 times
Yikes! I really don't envy your East coast cars. They sure get crusty. We get corrosion here too with the road salt and de-icing agent used on the roads, but still not typically that bad. They only cars that get that bad are the ones that never get fixed and sold when the last straw breaks.
Well, I got stuck in Hades on this job. The new drum/rotor wont go over the new shoes , even taking special care to make sure everything is in the right place. Even the old shoes wont fit in the new drum
Put it back together with new caliper and pads, no Parking brake installed.
Grrrr.
Grrrr.
- A0709D07-044E-4801-B89A-5E5765A630B7_1_105_c.jpeg (142.79 KiB) Viewed 896 times
- D4BE2E7C-C2C3-4C6C-BE0E-0866672339CF_1_105_c.jpeg (164.65 KiB) Viewed 896 times
- 793D7C2A-6EE3-42E9-A868-C64C265D6B1D_1_105_c.jpeg (118.18 KiB) Viewed 896 times
- 05DCA15F-1033-4553-8CB0-E949CE1F96CB_1_105_c.jpeg (143.25 KiB) Viewed 896 times
- EE25263B-4EDB-45F5-A343-BF7705BAAADE_1_105_c.jpeg (125.03 KiB) Viewed 896 times
I seem to recall there are 2 sizes of rear shoes on the P80's. I've been caught out with this before.
There are
31262626 are for FWD and what I am using here.
Shoes labeled 31262484
31262622 are for AWD and R (?)
31262480
I have a set of each, so maybe Ill compare the 622 with the 626 and see if they will fit
Those shoes are no where near seated into the shiny Cd plate metal loop retainers.
Hmmmm
31262480
Hmmmm
- 401C0CCE-134C-451C-8090-773BDFA1512B_1_105_c.jpeg (92.92 KiB) Viewed 884 times
Confirmed I have 626 shoes.
Now to confirm the hat is tight.
Circling back to this job. I bought 622 awd and 626 fwd rear parking brake shoes to see if this was the problem
Hmmmm
Hmmmm
Maybe I’m using awd disc/drums and got my parts muddled?
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
There is one I know you can look at and likely salvage good parts from.
The 626 shoes sure have a deeper notch into the actuated side of the shoes. Unless the problem is the disc/drum, it sure seems like the shies aren’t close to the right position on the backing plate. I recall at rest, the chrome clips are almost fully engaged on the shoes at the rest position, mine are less than half ( photo upstream)
- 15 Replies
- 6520 Views
Last post by wizechatmgr
- 2016 Views
- 836 Views
Last post by 98v70dad
- 1004 Views
- 827 Views
Last post by br0dy519
