2006 XC70 Evap pump replacement process Topic is solved
This topic is in the MVS Volvo Repair Database » 2006 XC70 Evap pump replacement process
Has thanked: 311 times
Been thanked: 817 times
I replaced the evaporator pump today on our 07 XC70. The original pump made it to 221k miles. Neil's write-up was a stellar guide.
On this vehicle it was not necessary to remove any rivets to get the heat shield out. Lower the exhaust, then drop the rear-most exhaust hanger bracket and the heat shield slides right out.
Other than the rust on the fasteners for the pump, the job wasn't too bad. I had some Oetiker clmaps bought originally for engine work, Volvo 976561 from FCP Euro, that were perfect size for clamping the hoses onto the new pump.
Has thanked: 1609 times
Been thanked: 4063 times
Bells ring in my house every time an oetiker clamp is crimped….
