P80 trapezoidal frame plate stiffener under car, part number 9133420 Topic is solved
Been thanked: 4065 times
Looking for part numbers for these two
Fwd just a plate
Awd/R has plate and bearing mounting fixture plus bolt holes
Found them on diagrams but no part numbers…#15 here
Has thanked: 2199 times
Been thanked: 1852 times
Based on your drawing, it would be #18 and #19 for AWD cars possibly?
https://www.volvocarstorontoparts.ca/a/ ... 76564.html
And those links are now safe from cia meddling thanks to image storing here ….
Fwd still available 9133420 ?
It is not listed as not-available from the website. It also shows it priced which often they don't do if it can't be ordered:
https://www.volvocarstorontoparts.ca/p/ ... 33420.html
I just want to be sure we are talking the correct part you are looking for/at. Are you looking for a cross member under the car or a cover plate under the car?
Cross me,her under the car
It’s 9133420
🇨🇦 rocks
VWAudirally
Year and Model: 1996 850 Wagon
Post by VWAudirally »
That part number is showing as retired.
I have asked my contact at Volvo parts to investigate if the other part number I listed a link for is actually available. It is showing as discontinued now at GCP.se
Just got an answer from my Volvo dealer contact. Part is NLA from them. Maybe worth contacting Volvo direct. I did this once and they found me the parts in Australia.
Sorry, but the website had not been updated it looks like.
Ok, this has been bugging me. For the life of me I cannot picture where on the underside these plates fit. I've tried to find pictures on the underside of P80's but no luck finding any of where these are fitted.
What is the purpose and can someone post where they are fitted so if I do a junkyard run I know where to look for non-crusty ones?
Thanks,
Right under the cat at its rear end. There are four bolts in the frame, M8, and it bolts ip there.
Flat plate on the FWD
AWD cars this plate also has a raised member and bolt holes for the driveshaft bearing
