Brake Light Replace
thiggy
Year and Model:
Post by thiggy »
I have a 2001 V70 XC wagon. My passenger side upper brake light assembly is damaged where the light snaps into the lens assembly (from excess heat, I think). I will need to replace the lens assembly, but I don’t see how to remove the old one. Does anyone have specific instructions? A diagram would be helpful also. Does it mount with screws, or clips which allow the light to snap off? The only access to the back side appears to be by removing the rear speaker, but even after doing that I cannot see very much. Thanks for any suggestions.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
You might find one cheaper on eBay than an on-line place. Shop around. I hope the following helps you:
V70 Rear Light Removal.pdf
(38.72 KiB) Downloaded 5401 times
If you need links to the other operations that you have to go through frist, let me know (loud speaker grille, etc.)
thiggy
Year and Model:
Post by thiggy »
Thanks for the helpful PDF, Madein. Is this document available to the average Joe, or is it from a subscription site? I am uncertain about the removal of the side panel cover, cargo compartment side panel and the cantrail panel.
MadeInJapan
These diagrams are from VADIS...a 2 DVD set you can buy from eBay. Here are some of the other parts to your process (you might not need all of them) that might be helpful to you:
Loudspeaker D-post.pdf
(31.52 KiB) Downloaded 2129 times
Cargo Compartment Side Panel Cover.pdf
(87.63 KiB) Downloaded 1726 times
Replacing Side Panel Cargo Compartment.pdf
(21.12 KiB) Downloaded 1387 times
Replacing Cantail Panel.pdf
(25.01 KiB) Downloaded 1358 times
Replacing D-Post Panel.pdf
(54.97 KiB) Downloaded 1364 times
Replacing Tailgate Panel.pdf
(23.97 KiB) Downloaded 1481 times
toddba
Year and Model:
Post by toddba »
Volvo workers, I am new.. Do I have to remove the lens (nice pdfs) to change my brake light bulb? I've opened the speaker, no real access. Looks complicated with a risk of breaking lens fasteners.
advice?
todd
2002 xc70
MadeInJapan
No...one of the pdf files should have the process. Reach in, twist the cover and pullout... no outer lens is ever touched.
