Baddddd... asssssssss...
Just replaced two bulbs in my 99 V70 XC... it was exactly as described in the how-to...
I got them from the honda dealership here and they said the part number changed from n-01 to b-02... whoopty doo... and they were $1.37 each, so I bought two and discovered I needed to replace two.
Hell of a deal for under three bucks and 15 minutes of work.
Volvo Radio Light Bulb Replacement
Current:
1999 Volvo V70 XC - 220,000
2000 Nissan Frontier Crewcab - 155,000
1973 Volkwagen Thing - 63,000
Previous
1967 VW Karmann Ghia Vert - 84,000
1967 VW Karmann Ghia Vert - 58,000
1971 VW Karmann Ghia Coupe - 112,000
Previous
All I can say is thanks a lot. I am not particularly handy but this walk through was so clear and easy to follow that I completed the fix in 20 minutes as was suggested. The current cost for the Honda bulb was $1.75 per unit at Goudy Honda in Alhambra, CA. Thanks again!
This works and I'm grateful for that since hitting the wrong button in the dark prompts the radio to ask for some setting or another that won't go away until the car is shut off. . However the bulbs in my case, purchased from Honda, have only lasted one year. This time I've decided to leave the little blue gel covers off the bulbs to see if they are keeping enough heat in the bulb to shorten its life. I like the incandescent look anyway
gklein4
- Year and Model: 99 XC70
The Volvo Bulbs that work is the following Part #30752175 they come 5 to a bag they retail for aproximatly 5.00 each & they are blue & give a nice soft light in the dark & yes these bulbs are used for the XC90 but they fit exactly & are cheaper then the bulbs for the switches
Glenn K
Glenn K
- Has thanked: 2858 times
- Been thanked: 1332 times
Just got this comment mailed to me from Christian:
Excellent post and instructions about replacing burned out lights bulbs in the radio. After hours of online learing about and searching for "neo-wedge" T1 bulbs, I finally called my local Honda dealer and picked up 10 of the smallest bulbs that fit the radio and two of the panel swithes. Then I went to Radio Shack and picked of 6 packs of the 272-1092 bulbs. I carefully unwound each of the taller T1 bulbs that are in the panel switches. Then re-wound the new Radio Shack bulbs back onto the taller "neo-wedge" bases for all of my panel lights.
Clearly, this DIY project is not for the non-technical. But, when Volvo wants $8.44 per bulb, instead $1.50 for a pair at Radio Shack, some intricate patience and technical skills sure pay off.
Also, in your post on the radio bulbs, I have a SC-815, and the face plate removal is different. It's a bit more delicate, but still easily done.
- instarx
- Year and Model: XC70 T6 2011
What I find funny is that out of all the posts on Matthews Volvo, the all time winner, with almost 14,000 views and 75 posts so far, is about replacing those %#*@ radio light bulbs!
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
SilverBullet
- Year and Model: V70 XC 1999
can anyone tell me the radio shack part number or what they call the bulbs for the radio lights??
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
This should help: https://www.matthewsvolvosite.com/forums ... highlight=
SilverBullet
it did MIJ.. thank you very much!
SilverBullet
Just wanted to say i changed all my bulbs on my radio by following the instructions in here... Great write up and instructions.. Took me about 30 min. to replace all 5. I chose to go with the radio shack way.. wasn't hard at all to rewind the wires into the holders.. Now all my lights work! This site is great! Thanks everyone
- 4147 Views
Last post by silentcircuit
- 4886 Views
Last post by adrian22
- 2643 Views
Last post by firstv70volvo
- 1474 Views
Last post by pkc303
- 2510 Views
Last post by mika
