04 2.4 S40 blower fan vibration
1996 - 2004 S40
1996 - 2004 V40
missionhills
Year and Model: S40 late model 2004
Post by missionhills »
Hello, I have a late model s40 with the 5 cylinder. My blower fan is vibratingl. The dash vibrates as I increase the blower speed. I've checked the cabin air filter and it's clean...any ideas? If the squirrel cage is out of balance do you have a procedure on removing the blower motor? It looks like an 8 hour job....eek
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Welcome to MVS.
2004 was a split year where the newer S40 is referred to as '04.5 so I'm not sure which one you have...if you have the older version then I can help you as I don't have information on the newer version. Anyway- here is the '04 instructions- not the '04.5 Hope it gets it...let me know.
04 S40 Climate Control R and R.pdf
(656 KiB) Downloaded 254 times
Oops, I did have the later model information- sorry about that- I'm posting it below (one of the above files should help you):
04.5 S40 Climate Unit R and R.pdf
(1.23 MiB) Downloaded 1470 times
missionhills
Wow, that's wonderful information! Do you perhaps have the dash removal proceedure? And yes this is the late modle S40. Five cylinder 2.4.
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
S40DashBoardRemoval2004.5.pdf
(884.22 KiB) Downloaded 460 times
S40CenterConsoleReplacing2004.5.pdf
(256.19 KiB) Downloaded 185 times
S40GloveCompartmentReplacing2004.5.pdf
(295.6 KiB) Downloaded 169 times
S40SoundproofingPanelRemoval2004.5.pdf
(261.49 KiB) Downloaded 138 times
missionhills
Thank you vegasjetskier- the files were perfect. I got the fan out and found a rat had got into the squirrel cage and eatin an inch off 4 or 5 blades it looked like I had taken a bite out of the cage. Thanks for your help.
vegasjetskier
missionhills wrote:Thank you vegasjetskier- the files were perfect. I got the fan out and found a rat had got into the squirrel cage and eatin an inch off 4 or 5 blades it looked like I had taken a bite out of the cage. Thanks for your help.
You're welcome.
Speaking of problems with rats, I found out why my PC wouldn't work:
:D
MadeInJapan
Haha! Glad you found the cause and hopefully the answer.
In the future, you have to feed him right and exercise that rat to keep him happy.
