Can I use a 16T turbo in place of stock 13G on a 99 V70XC w/
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
I read that also. Keep in mind that the larger turbo will take longer to spool up, so your low end won't be as good. But it will flow more cfm, so your maximum hp should be higher.
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Yes, you can do that but to get the most out of the larger turbo (spooling up faster, etc.) get a proper tune by allowing someone like IPD to tune your ECU to fit the larger turbo- call Lucky or Scott at IPD ( www.ipdusa.com ) and they can help you! Tell them that Dave (MadeInJapan) recommended you. Btw, some 16T's have an angled flange (that connects to the downpipe) while others are straight...you need to match what your current turbo has in order to keep from fabbing up a new downpipe, so check what you have first before proceeding with a purchase.
