Noise and shake with the Alternator belt
1996 - 2004 S40
1996 - 2004 V40
Oreste
Year and Model: S40 2001 1.9 t
Post by Oreste »
Hi I have a Volvo S40 1.9 turbo 2001, I would like you to help me to identify by means of the picture or video that I am attaching you if this shaking and noise is normal by this spare which I do not know if it is a tensioner of the alternator double sided belt. The shaking and noise intensifies once I turn on the A/C.
Many thanks, best regards
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
That looks like the tensioner. Your video didn't post up. :?:
Oreste
Post by Oreste »
Thanks you are right is the tensioner... the video I can not load it cause is to big.... the main problem is that this belt tensioner is giving noise and shaking is there any way I could give it some maintenance or do you think I have to replace it..... in that case can you give me a link where to find it and the instructions to replace it?
vegasjetskier
I don't think it's servicable. You can get a new one from your local dealer, www.myswedishparts.com, www.swedishautoparts.com, www.tascafordparts.com, Darrell Waltrip Volvo 1-800-689-0021 ask for Jamie or Don, and maybe www.fcpgroton.com
vegasjetskier
These are the closest directions I have. After you get the belt off you'll need a socket to remove the center bolt from the tensioner.
S40-2001-ReplacingAuxBelt.pdf
(107.04 KiB) Downloaded 350 times
vegasjetskier
Are you sure the tensioner is your problem? It could be that one of the other bearings are going out and that variation in tension on the belt is causing the tensioner to shake back and forth. When the AC is engaged additional load is placed on the belt, which causes the bad bearing to "stick" more, causing additional shake.
