MAF sensor problem?
Hello: I was driving my very solid 1998 S70 on a trip this past weekend, when all of a sudden, the engine began to lose power and stalled. It would restart, but it would only run for 3 to 4 seconds. After letting it sit for 20 minutes, it started and ran for about a minute (rough) then stalled again. No "check engine" light has come on. A shop tells me the fuel pressure checks good. Could this be an MAF problem?
- Year and Model: Many Volvos
- Been thanked: 76 times
It could be, try to just unplug the MAF and see if it smooths out. Unplugging the MAF will trip the CEL but it is easily reset. Has your engine temperature gauge been behaving normally?
the check engine light may not come on for few ignition turns after the malfunction has occured thus a few more starts or attempted starts should bring up the codes and give you an indication as to what the ecu has seen that has gone outside normal parameters ,i agree unplugging the maf would be a good check,
- 1551 Views
Last post by jwalker275
- 16 Replies
- 2756 Views
Last post by 93SCMax
- 10 Replies
- 1915 Views
Last post by albertoVO5
- 26 Replies
- 6492 Views
Last post by ChadLee
- 3141 Views
Last post by itsmekirby
