S70 1998 White Smoke
Steves70
Year and Model: 1999 S70
Post by Steves70 »
I have a Volvo S70 1998. I get 3 codes PO410, PO172 & PO108. The car runs good but blows smoke out of the exhaust and only when I let off of the gas.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Code po172=long term fuel trim/lower limit,the other two codes i don't have in my conversion table of standardized trouble codes.
You said that white smoke comes out of the exhaust....that could be only related with head gasket....white smoke is usually the sign that your head gasket is blown.
Does your car loose coolant?
Check your oil dipstick for water in oil,or coolant for oil in it.
Are you sure that is not blue or black smoke instead of white?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Welcome to MVS,
As Misha said,
You have some codes that are not necessarily related to the smoke. Can you describe it a bit more as in what color the smoke is?
If the smoke is black or it looks gray in color the P0172 and the P0108 are the likely culprits.
Normally the P0172 (a fuel trim limit code) points to broken vacuum lines but the P0108 (MAP sensor) could cause it as well.
The P0410 is a Secondary Air System code that indicates that a failure in either the SAS air pump or the SAS valve - normally they kinda fail together. The SAS has no real effect on drive-ability but it will keep you from passing a smog test if you have one in your area.
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
The white smoke could also be because of the turbo. If you do a compression test and everything is normal and there is no coolant in the oil or vise versa, then it is the turbo.
bdnolan2
Year and Model: S70 GLT 1998
Post by bdnolan2 »
I have same problem with mine smoke is gray to blue and I have noticed that my coolant overflow is getting low!
Year 1998
S70 GLT Turbo
Color Black
Mi. 141,000
Int. Tan
bdnolan2
Post by bdnolan2 »
Does any one know where I can get a free down load of a pdf for the service manuel
Year 1998
S70 GLT Turbo
Color Black
Mi. 141,000
Int. Tan
FCPEURO
Post by FCPEURO »
I would just do a search on google for S70Manual.pdf. That will come up with something for you.
misha
Post by misha »
bdnolan2 wrote:Does any one know where I can get a free down load of a pdf for the service manuel
Here it is:
https://www.matthewsvolvosite.com/downlo ... vo_850.zip
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
bdnolan2
Post by bdnolan2 »
Same as the 98??
Year 1998
S70 GLT Turbo
Color Black
Mi. 141,000
Int. Tan
bdnolan2
Post by bdnolan2 »
Sorry same as the 98 S70
Year 1998
S70 GLT Turbo
Color Black
Mi. 141,000
Int. Tan
