S70 1998 White Smoke
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Code po172=long term fuel trim/lower limit,the other two codes i don't have in my conversion table of standardized trouble codes.
You said that white smoke comes out of the exhaust....that could be only related with head gasket....white smoke is usually the sign that your head gasket is blown.
Does your car loose coolant?
Check your oil dipstick for water in oil,or coolant for oil in it.
Are you sure that is not blue or black smoke instead of white?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Year and Model: Many Volvos
- Been thanked: 76 times
Welcome to MVS,
As Misha said,
You have some codes that are not necessarily related to the smoke. Can you describe it a bit more as in what color the smoke is?
If the smoke is black or it looks gray in color the P0172 and the P0108 are the likely culprits.
Normally the P0172 (a fuel trim limit code) points to broken vacuum lines but the P0108 (MAP sensor) could cause it as well.
The P0410 is a Secondary Air System code that indicates that a failure in either the SAS air pump or the SAS valve - normally they kinda fail together. The SAS has no real effect on drive-ability but it will keep you from passing a smog test if you have one in your area.
As Misha said,
- misha
Here it is:bdnolan2 wrote:Does any one know where I can get a free down load of a pdf for the service manuel
https://www.matthewsvolvosite.com/downlo ... vo_850.zip
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 2278 Views
Last post by Sommerfeldt
- 13 Replies
- 1991 Views
Last post by misha
- 787 Views
Last post by tryingbe
- 2033 Views
Last post by Ben850
- 1603 Views
Last post by precopster
