My bad. I think I was thinking of the serpentine belt that I had to loosen the idler pulley for. I think I had more difficulty getting that back on than the timing belt. But I did leave something a little lose to do that belt as well.
Obviously I need more tea this morning.....
Timing Belts, Luxury and Tears...
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 128 times
I was super thankful and surprised that my gasket mostly came off in one piece. The only part that stuck was the upper right corner that can't be seen.
I completely understand needing to walk away, and not making it back for awhile...done that plenty of times. Sometimes the initial "getting back to it" is just a reevaluation of where Ieft off.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1497 times
- Been thanked: 3810 times
I did 16 times in 2 days. Practice is how you get to Carnegie Hall.....Eddystone wrote: ↑16 May 2022, 08:27 The first time I did this was on an S40, and I had no idea that the car had variable valve timing and that the exhaust cam would move when the belt came off. I was working on a friends car in a barn miles from anywhere with only the tools I brought with me in may car. This was before I owned any P80s. I had that belt on and off so many times wedging the sprocket with blocks or wood I found in the barn. It was a horrible nightmare that has scarred me for life.
Eight minutes, huh? Being an MVS Moderator, I'm surprised that you would ignore forum rules regarding bragging and inflicting mental anguish of fellow posters.![]()
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
Well, I almost hate to admit it, Mr. Sixteen Times in Two Days, but your technique is what finally got the belt on, though I came up over the tensioner last because it had no teeth to align with. In the end, everything looks right , and the timing marks look good, but if there are issues in a few days when I start it up, I'll be blaming you!
Getting the second bolt into that little guard below the crank was also excruciating. I don't know why it was such a struggle.
While the coolant is out, I want to replace any of the coolant carrying hoses that I haven't already done, especially those two little turbo coolant lines behind the engine.
All U.S. market models.
All running and on the road.
- Has thanked: 1836 times
- Been thanked: 1709 times
Turbo coolant pipes can be stinkers but at least you don't have AWD! I did the upper and left the lower to the dealer with a hoist!
Volvo only for the little turbo hoses , and the oetiker clamps are a breeze there. I cut them off and lube them to put them on. Professor Potato recently posted a rubber safe lube of isopropyl alcohol, aka, rubbing alcohol.
- Eddystone
Got the Volvo ones in hand. Early on, I used a Euro hose 2" long in the EVAP system by the fuel filter. Went bad and cracked within 6 months. That was just vapors...
- 1213 Views
Last post by WarbirdPilot91
- 2156 Views
Last post by velorider
