V70 Geartronic - new valve body?
Willber
- Year and Model: 2.4t 2002
- Has thanked: 5 times
There is sludge on the drain plug magnet between drain and fills, certainly when I did it last which was circa 5k miles since the last one (with several more before that in short succession to replace as much fluid as possible). When I say sludge I mean that I can clean 'stuff' off of the drain plug magnet before reinstalling...
Does that imply more friction material wear than usual?
Thanks
Thanks
Willber
I thought it was quite normal to get that. Flakes/chunks in the old fluid would be more concerning I'd imagine?
Another thing ive noticed; if I drive the car in manual geartronic mode and shift gear myself, the car then drives smoother once I put it back into auto mode again. This makes me think manual geartronic mode frees up the solenoids or gearbox somehow compared to auto?!
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
These are filtered out. Only a soot-like particles can sneak by the fine filter mesh.Willber wrote: 25 May 2022, 11:51 Flakes/chunks in the old fluid would be more concerning I'd imagine?
Run transmission adaptation cycle (need DiCE/VIDA for that).Willber wrote: 25 May 2022, 11:51 Another thing ive noticed; if I drive the car in manual geartronic mode and shift gear myself, the car then drives smoother once I put it back into auto mode again. This makes me think manual geartronic mode frees up the solenoids or gearbox somehow compared to auto?!
Willber
My neighbour has a professional diagnostic tool (not Dice / Vida) but has the options on it. I will do the Reset Adaptation and see how that goes rather than the full Control Module Adaptation (requiring the driving procedure/flashing triangle on dash)
