Uneven brake pressure front and back.
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Both cables are probably seized. Do you just say parking brake overhaul because of the rust cn90 ? I don't see how that rotor wear would have anything to do with the parking brake.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
goldxc70
- Year and Model: XC70 2004
- Has thanked: 27 times
- Been thanked: 3 times
The pads are pretty new and have lots of material left on them. Pins were polished and lubed when they were installed. Hadn't heard of Max before but will definitely check them out.Herb Goltz wrote: 10 Jun 2022, 07:55 Man, those are some rusty rotors (even by Ontario standards!)! Very poor pad to rotor contact. Having a similar issue with my 2006, just bought pads and rotors. I have been buying pads and rotors from Max Advanced Brakes in Markham-- less than $100 taxes in and delivered. Make sure you lube up the caliper pins.
- Has thanked: 1611 times
- Been thanked: 4075 times
Those rotors will clean up but they will eat up the pads badly. If you took a flap disc to them and get them smooth the pads will thank you and wear them in like mirrors.
- Been thanked: 504 times
Most of the cars' parking brakes friction material falls off after 10yr/100K miles...
Info in forum.
Info in forum.
cn90 wrote: 10 Jun 2022, 20:58 Most of the cars' parking barkes friction material falls off after 10yr/100K miles...
Info in forum.
In our nasty salty climates where brake rotor life is about 5 years max, it makes total sense to refresh the parking brake shoes when doing the rear brakes, especially on a manual transmission car
- br0dy519
Maybe I should reinstall the parking brake on my wife’s car this year with a new, unseized cable.abscate wrote: 11 Jun 2022, 04:34cn90 wrote: 10 Jun 2022, 20:58 Most of the cars' parking barkes friction material falls off after 10yr/100K miles...
Info in forum.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- 13 Replies
- 4058 Views
Last post by WhatAmIDoing
- 1774 Views
Last post by Shanestrait
- 650 Views
Last post by br0dy519
- 12 Replies
- 2472 Views
- 18 Replies
- 9913 Views
Last post by Orchid70
