Nay the door wiring connector on P80 cars is standard torx, T10. These are the only external torx on the car:
E5 ABS module
E8 door hing pin
E14 hub bearing bolts
I'd not bother getting a whole set unless you have other cars that need them or it makes more sense cost-wise. I've got those three and hardly ever use them. Any others will just sit in your tool box, unused.
E8 and E5 can be low quality these are low-torque, easy access locations. The E8 you may never use and for sure you could cheat it with a hex or even pliers in a pinch. The E14 I'd recommend a quality piece for if/when you need to do a wheel bearing.
Going to start with the ABS module
- Has thanked: 312 times
- Been thanked: 818 times
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I think I've seen the hinge pins, now that they're mentioned.
This is what I'm planing on getting if it's in stock locally
https://www.harborfreight.com/14-in-dri ... 68017.html
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Looks like a great solution, thanks for posting.454cid wrote: 31 May 2022, 12:16 I think I've seen the hinge pins, now that they're mentioned.
454cid
I just got my sockets.... the local store ran out, and I had to find another store. I was over that way any way, playing hookie from work, and trying to look at another P80.... a V70. Not in the greatest shape, and high miles, but minimal showing rust. Maybe if I can get it cheap. Unfortunately, the keys were locked inside, so I couldn't do much but look at the outside.
Any good tricks to getting into a v70 without keys, that doesn't cost money, or damage? I tried my 850 key/remote, but that didn't work.
Supposedly it smokes, and the throttle sticks.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 1613 times
- Been thanked: 4078 times
You can order a key by VIN number if you can get the registration document to a local Volvo dealer. Otherwise it’s a visit from a locksmith with a slim Jim. Volvo’s aren’t easy to sim Jim though
454cid
I was thinking before purchase.abscate wrote: 02 Jun 2022, 16:17 You can order a key by VIN number if you can get the registration document to a local Volvo dealer. Otherwise it’s a visit from a locksmith with a slim Jim. Volvo’s aren’t easy to sim Jim though
Does anyone slim jim anymore? It seems around here, they bend your door out with a balloon, and then reach in with something.
Hopefully they have another key. The man I needed to speak with was out today. I could see a key in the ignition that is supposedly stuck.
I was already with my Bluetooth and 850obd2 to check out the O2 sensors to see if that might be why it smokes.... I did not see soot at the tailpipe, Though.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 2215 times
- Been thanked: 1853 times
What year is it? You are not supposed to be able to lock the keys inside a 99-00 car without a key.
You won’t balloon a Volvo door. Find someone who knows P80 Volvos so they won’t damage it
454cid
I wondered how it happened because of that. It's a 98, but even my 96 fights me when it comes to locking, but I've never bothered to figure out all the conditions. There are times, I've wanted to lock it, and it won't let me.scot850 wrote: 02 Jun 2022, 17:09 What year is it? You are not supposed to be able to lock the keys inside a 99-00 car without a key.
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
I'm hoping they find another key. Right now it's not my responsibility or place to get it open. I really don't even have room for the car.abscate wrote: 02 Jun 2022, 18:42 You won’t balloon a Volvo door. Find someone who knows P80 Volvos so they won’t damage it
On another note, all 4 of the E5 bolts, on my 850, broke loose with ease.... well after I was able to get the socket on the screws at that awkward angle. The lower front was the most difficult. I'll pull the module Sunday evening, and send it out.
I think shorter sockets might be easier for a couple of the screws, but whatever.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- 11 Replies
- 7387 Views
Last post by Vovoroom
- 6156 Views
Last post by misha
- 1652 Views
Last post by Dzikiewicz
- 537 Views
- 2298 Views
Last post by yagger
