Best way to get wiring from front to trunk Topic is solved
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
^ Thanks for those pics. Exactly what I needed to see. And just what I think I want to avoid. But a quick glance under the car showed a plausible path following and attaching to the brake line, then drill and grommet a la B.B.
Thanks guys !
1999 V70 GLT
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Goupil wrote: 14 Oct 2022, 14:33 I've tucked mine inside the plastic conduit on the driver (left hand) side. Had to lift the carpet and take a few trim pieces off, but wasn't too bad
Yeah, this is pretty much what I was talking about.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Chuck W wrote: 15 Oct 2022, 19:08
+1 for running wiring the same place that Volvo does.
There isn't any factory wiring running from the front
to the back underneath of the car for good reasons.
You're just asking for trouble - Keep it inside.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I ran my hot wire for the trailer electronics underneath the car. Super quick install :roll:
BMW 540i 2002
S70 Base 2000
Sveedy
Post by Sveedy »
Well there is wiring under there to the rear o2 sensor, so I would think that properly shielded and attached, I could go the couple of feet longer to get to the trunk. I think it's going to be one of those fun things that will be determined when I wade into it.
But I very much appreciate the input. I'll post my results for posterity.
1999 V70 GLT
Sveedy
Post by Sveedy »
Looking at the first pic by Goupil, is that flat black piece of plastic by the rear door an actual cover for a wire raceway / conduit or is that just a piece laying there ? I'm probably going to have to feed 4 or 5 wires front to back.
1999 V70 GLT
Chuck W
Post by Chuck W »
Yes, it's a wireway.
Sveedy
Post by Sveedy »
Well in that case, I think it's worth a trip to the automotive repair lab, aka the junkyard, to see if I can remove those sills / carpet without damaging anything. Maybe ( hoping ) it will be easier than I'm thinking , but otherwise it's going under the car.
I could actually run the wires inside a rubber hose like vacuum line, instead of the plastic wire loom stuff if more protection is needed.
1999 V70 GLT
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1076 times
Post by volvolugnut »
Sveedy wrote: 17 Oct 2022, 08:41 the automotive repair lab, aka the junkyard,
THAT is a great concept.
Has thanked: 1610 times
Been thanked: 4071 times
If tailess monkey Abscate can run wires in the rocker panels, so can you. :-)
