1998 V90 Best way to replace voltage regulator?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
martin calva
Year and Model: V90 1998, 945 1995
Post by martin calva »
I want to replace the voltage regulator on my V90 (Low voltage when engine running + battery is never more than 50% charged even after a long run).
The alternator is well hidden below the steering pump and it's not obvious to me that the regulator can be replaced while the alternator is in its place. What is the best way to replace the alternator's voltage regulator:
[A] Do it with the alternator in place, removing some of the piping that makes its rear inaccessible?
Remove the auxiliary belt, then the alternator and replace the regulator with the alternator out of the car?
Thank you for any advice - Martin.
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
martin calva wrote:What is the best way to replace the alternator's voltage regulator:
On the bench, and while there, one can test bearings via spinning alternator via hand. If bearings sound "dry," then replace them, or buy a rebuilt
martin calva
Thank you for the advice.
