One more comment. I eliminated the whole mess by cutting the top half off the aluminum pipes coming out of the heater core and slipping heater hose over the pipes. Double clamps are advisable here because the lack of a flange on the end of the aluminum pipe where you cut it off makes leaks more likely.
I took the black double hole plastic fitting that sits in the firewall and removed material until the outer diameter of the heater hoses slip fit snugly through the holes. Then removed the stock heater hoses from the engine.
The result is a hose running directly from the clamp at the engine through the firewall to the clamps on the heater core pipes. This eliminates 25 year old plastic fittings and a bunch of o-rings that in my opinion are too expensive and too failure prone.
Just my 2 cents.
Volvo 850 heater core o-ring question
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
- Has thanked: 311 times
- Been thanked: 817 times
I ran hoses to the pipes for a few years (viewtopic.php?t=46253), has pros and cons, but finally went back to the coupler. Some comments in viewtopic.php?t=98579.
- Has thanked: 2203 times
If you can manufacture a swage on the end of the aluminum pipes then there is an argument to going that way. Downside is if you done, there is a chance of a leak, but the coolant pressure is not all that high. The other issue is ensuring the hose does not rub on the surround in the firewall.
Your point Erik is on the '25 year old plastic going brittle' as is greg850r. Put in context, are these car going to be in use in another 25 years time? So the 'chore' of fitting a new part that worked for 25 years (assuming it in OE Volvo) seems to make a lot more sense.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
Abscate: not only a veritable font of knowledge regarding the P80 platform, but clairvoyant, too! How else could he know that on my bucket list is a car trip in my 850 to backwoods Egypt?
- 687 Views
Last post by darylrobert
- 812 Views
Last post by trekking
- 11 Replies
- 9854 Views
- 5087 Views
- 32 Replies
- 17760 Views
Last post by sleddriver
