07 XC70 driver's side blows warm air with A/C on Topic is solved
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Did you check the pressure to see if it was low on refrigerant charge yet?
04s60 2.4
04xc70 2.5t
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Both low and high pressure can lead to warm air out of vents.
Has thanked: 1611 times
Been thanked: 4075 times
Incorrect charge can put a temp gradient on the evaporator and cause the side variation in temperature. BMW really sees this with a small charge loss.
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Thanks for replies!
I did check low side pressure initially, before even posting. I it was like 27 so I wrote it off, thought it was about what i normally see on my P2's with this gauge. But I'll get a careful reading and report back.
vtl
Post by vtl »
You need dual gauges for both low and high sides. Also a thermometer, high side pressure depends on the temperature. Once I got a dual gauges set, I'm able to fill the A/C on my own. Oh, I also got an A/C vacuum pump.
Post by erikv11 »
Noted, thank you. I'll check them both as I have a dual gauge set too. Harbor Freight but it works. Haven't splurged for a pump yet I have been borrowing one from FLAPS.
Post by erikv11 »
Engine warmed up, AC compressor running with fan on highest setting.
Permission to charge, captains?
vtl
Post by vtl »
75 F, 15 PSI low, 135 PSI high? According to internet charts, R134a at this temperature should be 35-45/150-170 PSI. I would add a bit and see how it goes.
Post by erikv11 »
Was checking psi as it charged and ended up finishing off the open can I had, about 8 oz (2/3 of a can) added overall. Definitely colder now on the driver's side so a big improvement but it still seems warmer than the passenger. We'll see how it holds up under demand. Readings are now 32/175 at 75 F.
Is it peculiar that the static pressure (engine running, AC not running) readings are not the same on low (65 PSI) and high (100 PSI) side? Seem too far apart to just reflect gauge (in)accuracy.
vtl
Post by vtl »
erikv11 wrote: 20 Jun 2023, 22:15 Is it peculiar that the static pressure (engine running, AC not running) readings are not the same on low (65 PSI) and high (100 PSI) side? Seem too far apart to just reflect gauge (in)accuracy.
The high/low temperatures are different, so vapor pressure is different. But high side will eventually boil off and expand to the low side if left undisturbed.
