2004 volvo s60 2.4 stalling issue
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
i'm not very versed on the maf but i think it goes into a closed loop when unplugged, the engine will run rich....but it will run.
maybe give it a spray with maf cleaner, dont get spray on the o ring.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
When you unplug/replug the MAF sensor, is it presenting a fault code? You would think it would.
Also (playing catch-up to this thread) by “brake booster” I was referring to the big vacuum diaphragm unit between the master cylinder and the firewall. Those units can start leaking with age. Can you hear the auxiliary vacuum pump buzzing often?
cichy1012
- Year and Model: 1999
- Has thanked: 1 time
no error code. no codes at all replaced the mass air flow and the car still stalls. when i drive around its fine. when i come to slow down the rpms start jumping up and down like 1000-2000 then boom the car dies. then i start it up and it drives.chrism wrote: 08 Oct 2023, 08:18 When you unplug/replug the MAF sensor, is it presenting a fault code? You would think it would.
swap out the throttle body maybe?
I dont hear any buzzing near the firewall. ill have to look more closely.
cichy1012
I replaced the maf sensor. Have not unplugged it since replaced. Replaced based off previous comment about car running better when unplugged and stalling when plugged in.jonesg wrote: 11 Oct 2023, 21:15 the maf is a problem, your code reader , whatever it is , doesn't seem to be helping.
unplugging the maf will set a code if read with vida.
- jonesg
genuine volvo part ?cichy1012 wrote: 11 Oct 2023, 21:35I replaced the maf sensor. Have not unplugged it since replaced. Replaced based off previous comment about car running better when unplugged and stalling when plugged in.jonesg wrote: 11 Oct 2023, 21:15 the maf is a problem, your code reader , whatever it is , doesn't seem to be helping.
chrism
You say the engine stumbles when you apply the brake pedal. If the car is sitting still and idling smoothly will applying the brake cause it to die or does it only die if you’re driving down the road and apply the brakes?
When it starts to stumble and you quickly release the brake pedal will the engine recover to a smooth idle or does it always die once it starts to stumble? Have you tried pinching shut the hose that provides vacuum to the brake booster?
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
I am suspecting the air intake hose between MAF sensor and throttle body has developed a fine crack -- age, engine vibrations, failing mounts, material deterioration -- it will be hard to see without acting like a Hanes Men's Underwear quality officer.
A home-made diagnosis and remedy would be to apply a layer of JB Weld paste along the lip at each end of the pipe and joints, and let it cure overnight. I was successful with high-heat aluminum tape on our 1997 850 to get us home.
- 760 Views
Last post by jenkinskg
- 7818 Views
Last post by enriquepr21
- 14 Replies
- 4409 Views
Last post by NathansC70
- 2031 Views
Last post by darylrobert
- 1626 Views
Last post by jjs70pdx
