07 xc70 no cabin heat or a/c
Has thanked: 1611 times
Been thanked: 4071 times
Sounds like the damper selecting cold hot air has given up. Bit surprising as there are two, for right and left.
You will have codes in the ECC control module if this is the case
jonesg wrote: 10 Dec 2023, 02:24
dcmike wrote: 09 Dec 2023, 17:07 I will check this tomorrow.
before doing surgery under the dash...
unplug the engine cooling fan, start the engine, drive around , do you get heat now ?
Most excellent!
dcmike
Year and Model: 1998 V70R
Has thanked: 2 times
Post by dcmike »
Thank you for all the replies. My son's car is away with him in Northeast PA so I'm not near it.
The thermostat and new ETS are working properly. He did disconnect the battery for a while and reset the car. The fan operates properly, turning off and on as temp requires. The climate control still does not work properly. He ended up taking the car to a independent Volvo mechanic outside of Scranton. He does not have time for the car until after the 1st of the year. The mechanic thinks its a wire.
I did purchase a used climate control unit from EVV. Do you have to do anything special if we replace the control unit, like take it to the dealer for any proprietary Volvo reset?
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Engine fan runs constantly when A/C is empty, even in cold weather. It also runs when ECT sensor is faulty (or its wiring).
T-stat may affect warmth in cabin, yes.
If a P.O. have used any stop leak products, it stops all the "leaks" through the cabin heat exchanger the first thing.
HVAC has 5 motorized dampers, they go bad.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
dcmike wrote: 22 Dec 2023, 07:20 Thank you for all the replies. My son's car is away with him in Northeast PA so I'm not near it.
before pulling the panel and unplugging connectors be sure to disconnect the battery neg terminal to prevent an SRS fault .
