And two rubber diaphragms (in compressor bypass valve and wastegate actuator). And pretty much can guarantee, cast iron part of turbo has cracks. I've seen old 3 turbos (around 170-220k), all had cracks.erikv11 wrote: 03 Oct 2024, 13:49 Issues with the turbo itself are extraordinarily rare. Main things are (1) use good oil see vtl's post and (2) be sure to keep on top of PCV maintenance and (3) be prepared to replace the large diameter rubber intercooler hoses about 180k miles when the hoses start turning to mush. Oh and there are several extra vacuum lines, be on the lookout for older, failing, decayed rubber vacuum lines.
2007 XC70: What should I know about a turbo-ed engine..?
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
- Has thanked: 311 times
- Been thanked: 817 times
Good point, I remember the days most P80 cars had leaky CBV diaphragms, I suppose we are getting there for the P2 cars now, too.
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Any info post on the rubber diaphragms? The XC70 has had a vacuum leak for 3 years and it sounds like somewhere near the turbo.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
vtl
Pull the hoses from TCV and suck/blow air with your mouth, you'll find which one is torn.br0dy519 wrote: 03 Oct 2024, 19:45 Any info post on the rubber diaphragms? The XC70 has had a vacuum leak for 3 years and it sounds like somewhere near the turbo.
- br0dy519
Oh I thought meant some kind of internal seal. You meant the yellow/blue/white tcv hoses
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Been thanked: 4070 times
Two turbos, two NAs.
Very little maintenance difference. 5k oil changes, synthetic Castrol
The T5 has the highway boost
The S70 LPT has it all off the line.
The 2 NAs sneer at the turbos as they pass them at the fuel pump, getting > 30 mpg
I can just get to 29 mpg on the T5 if I keep the speed at 55 and no boost
vtl
I get 14 MPG in summer. Healthy 1 MPG more than in a pickup truck.abscate wrote: 04 Oct 2024, 03:32 Two turbos, two NAs.
- 1007 Views
Last post by AylmerQc
- 1307 Views
Last post by benpineapple
- 814 Views
- 4944 Views
Last post by brentcd
- 1803 Views
Last post by Samzebian
