850 1995 pcv system without hose to the head from the oil trap
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
LH 3.2 Jetronic.
One is for engine,the other one is for ignition.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
viewtopic.php?t=62436
Looks like early B5254FS didn't had that hose for pcv on top of valve cover.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
classical
Year and Model: 1995 850 N/A 2.4
Been thanked: 5 times
Post by classical »
Ok. Well, I will see then what the oil trap is like and where the hoses go when (or if) I get the intake manifold out of the way. Thank you all so far!
DennisCA
Year and Model: 1996 850
Has thanked: 6 times
Been thanked: 71 times
Post by DennisCA »
That is certainly an odd one. I'd like to see where the trap goes as well.
misha
Post by misha »
It should connect to flame trap housing or big plastic hose which goes to throttle plate.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
classical
Post by classical »
This is what i found. Only one hose goes up from the box to the throttle plate, in addition to the short elbow hose obviously.
misha
Post by misha »
Pcv breather box have only one output?
I can't see clearly....knock sensor connector is blocking the view.
What about that little hose which looks like it's cut?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
classical
Post by classical »
it is like this box (viewtopic.php?f=1&t=55470) but the hose from top of engine is missing.
misha
Post by misha »
I see only one port on the breather box from your picture.
Those from the link have two ports.
There is a Volvo part # on your breather box.
Can you read it and post it here?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
classical
Post by classical »
My box is in other ways similar to the box behind the link except my box has only one port on top of the box. The part number: 6842718.
