Type and how much brake fluid for pressure flush - P80 and P2
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 276 times
Been thanked: 84 times
Post by hausmeister »
scot850 wrote: 18 Apr 2025, 08:42You can of course now buy cheap brake fluid testers, but I don't know how accurate they are. Come to think of it I may have one! If I have and can find it I will try and see what it tells me.
I use one of these cheap testers for a few years now, I think it works good enough to tell when your fluid is going bad. Before I replaced the leaking ABS pump It only lasted 1, maybe 2 years in the 850, after I replaced it it is now much less moisture ingress. Results from the tester mostly matched the yearly inspection results for me.
Important thing is to clean the 2 contacts and to fully submerge them, partway can give a different result.
850 T5-R '95 auto Image
