Experiences with Cam/Crank Locking tools?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Has thanked: 293 times
Been thanked: 765 times
Re: Experiences with Cam/Crank Locking tools?
Post by erikv11 »
abscate wrote: Today, 04:03 I’m struggling with that crack.
The load is spread out over the 26? Splines so any one spline sees very little load, but on the von side, the pulley is getting 2000 strikes per second of impact. That impact is damped by the pulley so the timing belt system doesn’t feel it.
I’m a viscous cheapskate but if I had this that far apart, I would replace it, especially since it’s hard to inspect.
That crack is probably at least 50% longer than it looks, and it’s headed for the locator pin.
Voice of reason. Replacing it is not a lot of money, compared to value of one lot of peace of mind.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Year and Model: 2001 V70
Has thanked: 929 times
Been thanked: 1002 times
Post by volvolugnut »
My thoughts:
Cracks tend to grow when exposed to cycling loads.
If the crack grows and the hub splits it will get looser and if the nut does not hold in place, hammer out the crank nose spline. A bad crank is likely a death sentence for older engines.
It is mostly disassembled and a used hub is $20.
I would change the hub without locking the crank and never worry about it again.
