I wanted to say thanks for the help and 'close the loop'. My 850 wagon has 92k miles and the R CV boot went bad. I replaced the axel, L and R struts, spring seats and strut mounts. The Right spring seat had failed so I'm glad I bought the full set of parts from FCP Groton. I was lucky to have air tools and the job took 4 hrs and 50 min. After alignment, the car is poifect.
Thanks again,
Mr_dave
99 s70 cv boot replacement
Putting a Value on a T-5R
rsmigel
- Year and Model: 1994 850 Turbo
- Been thanked: 2 times
I accidently pinched (tore) my RH side INNER CV Boot while replacing the OUTER CV boot, and have attempted a temporary repair using a bicycle tire patch kit. I doubt it will hold but I'm trying anyway as I don't want to pull the whole thing apart after I just put the whole thing back together.pfeener wrote:The LH side has a cir clip, but it's nothing you have to compress or remove. It works the same as all the other cars you've worked on. You need to apply enough pressure with a pry bar to overcome the clip holding the axle. The RH side has no clip. Once the intermediate bearing cap is removed the axle will slide right out.
A few questions:
1) Do I need to use a hammer to tap the axle out of the tranny once I take off the intermediate bearing cap?
2) Will the tranny fluid drain out of the hole after I pull the axle? If so, I'll need to buy more fluid.
3) Does the inner CV joint disassemble just like the outer joint by spreading the C-clip? With the constrained space, I don't see doing this 'on the car'.
- Has thanked: 17 times
- Been thanked: 35 times
Bicycle patch kit might work. If you can leave it without driving it for a day, you might reinforce it with RTV just to be on the safe side- just keep an eye on it.
For your questions, really depends on which side (for question
1). The passenger side seems to slide out for most people with just a tug. The driver's side tends to take the 2 prongs opposite each other to get the axle past the circlip. I guess I would be concerned as to where to hit with the hammer- you don't want to bugger up any of the attachment sections. Best to try to "pry" out of the transmission when possible rather than banging.
2). Some tranny fluid might drain out. I bought the transmission to axle seals just in case it was more than draining out "over" the seals but never had to use them. You won't lose much at all (unless you're talking about a manual transmission), but yeah, it's always a great idea to have a bottle of transmission fluid around (most use regular Dexron III if you're wondering, although if your car is a 2000 model or later, it could use JWS-3309 fluid, so check your owner's manual).
3). To do the inner, I also don't see how you'll do it it with the axle still attached to the tranny. If you're in that far, best to pull it out and do it on a work bench. The inners come apart exactly like the outers. Hope this helps.
Btw, Happy New Year!
-MIJ
-MIJ
rsmigel
This is the right, passenger side inner CV boot. So when I take off the intermediate bearing support, then the entire axle should slide out, right?
Good idea about the automatic transmission seal. Is that easily pried out?
Yes, and yes...on your second question, a sharp object, like a pick helps with this...be careful not to score the inside of the opening. Good luck and let us know how things go.
rsmigel
It appears that my 'bike patch' fix fails consistently after about one month; the grease just seems to break downt he glue bond. So now I'm in the process of removing my passenger side axle and I'm wondering if the type of c-clip holding the inner CV joint together is the same type of c-clip used to hold the outer CV joint together. If so, then I've got the correct c-clip pliers and I don't need to buy another.
I've got a 1994 850 turbo wagon.
Thanks in advance!
Thanks in advance!
Brucebo
- Year and Model: 850 '96, S70 '99
- Has thanked: 3 times
- Been thanked: 5 times
I just replaced the left front axle on my wife's '96 850. The outer boot was torn. The most difficult activities I encountered were getting the ball joint free of the spindle, and getting the axle out of the transmission. For the latter I finally ended up using a flat pry bar coming up vertically from underneath to pry it loose. This was the only spot where I had enough clearance for the pry bar. I also had to wrestle with the spindle to get it back into the balljoint because of the residual forces from the strut, tie rod, and sway bar. It would have been easy with two people, one to hold the spindle and the other to align it and push in the balljoint, but with only me, right hand trying to hold and align the spindle and left hand trying to push in the ball joint, it proved somewhat difficult. One mistake I made was at one point I wanted to turn the wheels to get some better access. In order to unlock the steering wheel I had to take it out of park. In order to take it out of park I had to put my foot on the brake, forgetting the caliper was off the rotor ..., out comes the c-clamp to spread the pads ...
-Bruce
-Bruce
- 11 Replies
- 6049 Views
Last post by default
- 924 Views
Last post by CThompson
- 762 Views
Last post by boneman131
- 1669 Views
Last post by rocketman4321
- 3130 Views
Last post by foggydogg
