Passenger window regulator well and truly hosed up....
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
You're welcome.
This one on Amazon says it has a 3" nosepiece: https://www.amazon.com/Astro-Pneumatic-4 ... 61&sr=1-17
bajaman123
Year and Model: 1999 S80 T6
Post by bajaman123 »
vegasjetskier wrote:You're welcome.
That one looks like it would be perfect, and very reasonably priced too.
Once again...I can't thank you enough for your help.
vegasjetskier
Bajaman, I wonder if you could straighten the bent arm and then weld some reinforcement along the edge?
Also, I think it would be prudent to look for the cause of the window binding up in the first place. It must have really been stuck to cause the arm to bend like that. If you don't correct it, the new regulator will probably suffer the same fate.
vegasjetskier
Here's a PDF of the VADIS procedure. It's for the driver's door, so it's a mirror image of what you're working on:
S80 WindowRegulatorReplacement.pdf
(149.15 KiB) Downloaded 831 times
bajaman123
vegasjetskier wrote:Bajaman, I wonder if you could straighten the bent arm and then weld some reinforcement along the edge?
Thanks for the PDF!
Yeah, I was thinking that same thing. WHY did it do it in the first place? I do think I will try to repair the existing one after I find out what was causing the bind.
bajaman123
SUCCESS! I was able to straighten on the arm once I took it out and then re-installed it, lubed up the window channel, and all is well again.
Thanks so much for all the help.
Here is a picture of the riveter that I bought, as well as the rivets. I was not able to get the factory rivets but found some that worked admirably well, from a company called SUREBONDER. These are multi-fit rivets that worked really well.
vegasjetskier
Excellent. Where did you get the riveter?
dcarlson12
Year and Model: 1997 850 T5
Been thanked: 2 times
Post by dcarlson12 »
Just wondering what you and perhaps others use for lubing the window slides.
This was done on one of my doors/windows by the dealer for the previous owner but would like to save the labor cost if and when I need to do it but would like to know what specific type of lube to use i.e. probably not axle grease??
bajaman123
I got the riveter from a specialty tool store locally, paid $60 for it. There are others out there of the same design for half that price if you search around a bit.
For the lube, I used Liquid Wrench white lithium grease in the spray can. Use care to keep it from getting on...EVERYTHING..., and a little dab'l do ya!
This forum is awesome.
