Name this part
This topic is in the MVS Volvo Repair Database » Name this part
C@lvin
Been thanked: 2 times
Post by C@lvin »
If you mean, how do you get the entire ashtray ("drawer" and assembly) out of the console......
In my S70 and V70 you first open the ash tray. This exposes two screws on each side at the rear of the assembly that must be removed. You'll need a light to see them up under there. There is also a tab at the top around where the ash tray light lens is but if I recall correctly, the ash tray "drawer" and assembly will just slide straight out after the screws are removed. I can't say if it's the same for your 850 but I suspect so.
Anyway, if that is not what you are referring to, then.............uh...never mind. :)
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
marginal
Year and Model: V70 D5 2003
Has thanked: 1 time
Post by marginal »
Thank you very much C@lvin.
That's exactly what I needed to know :idea: .
I saw some of these for sale on ebay tonight and was wondering how to access the screws for those two wholes that are seen on each side, but now I know 8) .
Thanks again.
marginal
Has thanked: 1 time
Post by marginal »
By the way ddpphx, you are talking about a "copper coil" but this is just about impossible :!: .
I mean for this coil to be made of copper.
It must be made of some steel alloy.
Vikingscrazy
Year and Model: 1995 960/ 1996 850
Post by Vikingscrazy »
It is the spring for you ashtray. It is what allows the ashtray to be pushed and then pop out.
marginal
Has thanked: 1 time
Post by marginal »
I know that :| .
I was just saying it can not be made of copper 8) ...
