Getting ready to change my evaporator...
This topic is in the MVS Volvo Repair Database » 98 S70 -- Fix headliner DIY
850FLA
Post by 850FLA »
OK, I changed the evaporator and receiver/drier and replaced the O rings. Buttoned everything up and aside from some minor problems with the drivers side control [cable broke] and recirc actuator arm broken [replaced] the ac is nice and cold.
I used the 850 proceedure along with the guide in pictures. Between the two it went pretty well.
I did not replace the orafice tube [just read this today].
I do get a high pitch sound when I shut the ac off [for a few seconds]. I had the same thing on my 850.
Is this fron the orafice tube?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Is this from the orifice tube?
That is normal, it is just the pressure equalizing. Unless you have had the compressor detonate on you, like all of my Chevy compressors, the orifice tube should be fine.
850FLA
Post by 850FLA »
Thanks Lee.
I assume I can still get to my drivers side heater flap as on my 850? My wife gets all the cold air!
Post by Ozark Lee »
Yes, you can get to it by removing the lower dash panel and it is right on the side of the climate unit. There is a stiffener board behind the carpet that you may need to remove to get access to it.
