Camshaft Position Sensor Circuit
Camshaft Position Sensor Testing Procedure
have you looked into the ignition coil? what about fuses and relays? also, how clean are the connectors for those sensors?
RIP: My Father 10/17/13 The Spiegel Grove claims another Soul.
"We are all the sum of our choices. The fear is not of dying... it is to not have lived."
Forever loved. Never Forgotten.
A splendid day to everybody.
Hi Ihailah.
I am curious how your story ends - sure by now your car is humming happily.
I'm actually in a similar situation (S90 Royal 1997 B6304S). But I think I blundered and might have destroyed something. I removed the starter lock w/o disconnecting the battery. Well I reconnected the cables and somehow the starter look was in position I or II. Does anybody know whether this would be a good way to blow the engine controller? I do see other things that do not seem right. On the drive mode switch S and E lamps are on, and the temp gauge does some right and middle and left. The other symptoms are pretty much the same: no spark, sparkplugs dry (fuel pressure at the bridge).
I'd appreciate If you could not dwell too long on the fact that I did a most stupid thing, I feel bad already...
Thanks for any advice
Hi Ihailah.
Evell Snoats
- Year and Model: V70XC 99
I have a 99 V70XC with the same code. Both wires 2 and 3 read 5 volts when I perform the tests. Any ideas?
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Note: moderators, can this be made a new thread starting with Evell Shoals post as Head post and maybe link to current titular post?
Checking Signal Cable
Ignition on.
Camshaft position sensor disconnected.
Connect a voltmeter between the camshaft position sensor connector 2 (engine control module side) and ground.
The voltmeter should read battery voltage .
If reading is OK:
Proceed to test step below.
If reading is incorrect:
Proceed to Checking Signal Cable Resistance to Ground section below.
Read through the above and try picking up at this step you describe improper voltage at pin 2-let us know how you doPost by Evell Snoats » 23 minutes ago
Ignition on.
If reading is OK:
Current Volvos:
Evell Snoats
Both pin 2 and pin 3 read 5v, not battery voltage. Using the instructions, I think I am at the verification section which says to check the cable between sensor terminal 3 and ECM A36. Problem is that my A36 is a blank slot!! There is no wire going to it for me to be able to test for an open circuit. Guess I need to look for a wiring diagram for my 99.
Evell Snoats
Found a wiring diagram and finally got the ECM out. Looks like the ground from the CPS to pin 3 (ground) has continuity to pin 65, but the others do not (pin 57 for power and 47 for the signal). Must be a break in those wires somewhere, although I don't know how they were showing voltage before? I am going to back up and start over and still see if I have any voltage at all.
Evell Snoats
Okay, after finding the correct wiring diagram (I was looking at the DENSO management system instead of ME7, I confirmed continuity from the CPS connector to the ECM. Went back through the steps. Still showing 5v at the power and signal wires.
Unless anyone has a better idea, I think I am going to try a new Cam Position Sensor. Going to do a little more research on the ME7 system to see if it outputs 5v instead of 12.
- Been thanked: 4068 times
ME7 has the cam sensor 7/21 wired to ECM A29, A47, A69
As a logic sensor it almost certainly be use a 5 V signal, not B+
- 2658 Views
Last post by Luzanov345
- 19389 Views
Last post by IronMike
- 1442 Views
Last post by cn90
- 558 Views
Last post by jackissocool
- 792 Views
Last post by cBobs94850T
