SAS removal walkthrough(No CEL!)
Project: 850 engine replacement woes (& Updates)
KlubMarcus
- Year and Model: V70 XC, 1998
Do you have to remove any parts of the SAS afterwards? Can you just clear the code, install the diode, and drive off?
- Has thanked: 311 times
- Been thanked: 817 times
Bottom line: yes, you can just drive off.
But read the link I posted, it is all described in excellent and accurate detail.
KlubMarcus
Will update in a week or two if any SAS CEL's show up. Just installed the diode across A32 - A37 and disconnected the pump. Everything else was left in place so it's totally reversible.erikv11 wrote:Bottom line: yes, you can just drive off. But read the link I posted, it is all described in excellent and accurate detail.
KlubMarcus
Update: drove the car for several days: stop and go traffic, highway driving, hot weather, over 100 miles. Still no CEL! Moderators, please remove the picture on top. The correct write-ups have the diode across A32-A37.
camelsong580
- Year and Model: 1996 960
Does this mod works for the 1996 960? Thanks in advance
I successfully did this, no more CEL for me. BUT, the car is running extremely rich when cold, like I have an open gas can sloshing around rich. Has anyone else had this problem, or know what I might have done to screw it up? The volvospeed link says to disconnect power to the air pump and the vacuum line at the tree. Power disconnected, and I only have one line hooked up to my tree, and I don't think it has to do with the pump.
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
Your problem is most likely unrelated to the sas delete. Check the basics; plugs, distributor, etc.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
ryanstrasser
- Year and Model: 1998
I was trying to download the pdf and it goest to an inactive message at volvospeed can some one email it to me or repost it for download? thank you!!
madspeed50
- Year and Model: 1998 S70 T5m
did this on my s70. Funny thing is the emmissions station looks my car up in the book to see what emmissions control devices should be present, and the air pump doesnt show up as present on a 98 s70
randallroot89
- Year and Model: volvo v70 1998
I have a 98 v70 I soldered the diode between 32 and 37 drove 200 miles...no code. Hooked up the obd no code....just started the car and let it idle for 15 minutes to warm up and I guess the pump is used most while idling and the check engine light came on. I didnt remove or disconnect anything for the pump I just installed the diode. How is it possible for the chec engine light to come on with the diode in place ? Im very confused and need answers.
- 944 Views
Last post by CIK7
- 1659 Views
Last post by lrock
- 1179 Views
Last post by CIK7
- 766 Views
Last post by wjhandy850
- 1334 Views
Last post by misha
