Gotta replace the secondary air pump on my 96'850 GLT
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
I replaced my pump last summer (which was the second time on the car) and from what I saw, the VW pump was darn-near the same price as the Volvo - my guess was that someone figured out they could make a lot more cake off of the VW's by making the same part the same price!
1997 855 GLT - R.I.P.
2006 S60R - For ME!
scumcity14
Year and Model: s70 t5m 1998
Post by scumcity14 »
Just do the delete..I have done it. NO codes, Passed emissions.. both OBDII and tailpipe test. eliminates 100s of dollars worth of pointless parts and never ending DTCs..Takes @ 5 minutes.
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
scumcity14 wrote:Just do the delete..I have done it. NO codes, Passed emissions.. both OBDII and tailpipe test. eliminates 100s of dollars worth of pointless parts and never ending DTCs..Takes @ 5 minutes.
Yeah it looks like I just do that...I have the money but why spend it on pointless BS!!
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
shiloh51933
I found the air pump check valve for 59.99 at partsgeek.com, it's after market but it's new and I'm ordering that to go with the air pump relay that I already have. I finally put my 850 on the road today since I can finally afford to have 3 vehicles insured/registered...can't wait!!!
chris k
Year and Model: 850, 1996
Post by chris k »
I've been reading through the paperwork I got on the 96 850 we just bought, and the diagnostic report came up with this same error code. Of course, this was in 2008, so I have no idea if this issue has been resolved. We're taking the car to be inspected tomorrow, so does anyone know how much this repair could run if it hasn't? I know there are a few variables as it could be the motor, check valve, etc, but a price range from least it might cost to most would be really helpful.
1996 850 - 138,xxx
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
$700-800 at dealer prices if the whole system is to be replaced (mine has been once under my ownership and several times before). Stupid expensive - the bypass is the way to go.
'98 S70 T5
2016 Chevy Cruze Premier
chris k
Post by chris k »
And the bypass doesn't show up when they do an inspection in VA?
1996 850 - 138,xxx
jblackburn
As long as the check engine light stays off, yes, it should pass.
If your pump is still running (I can usually hear mine on cold days), replace the relay and/or SAS valve and you may still have a working system.
'98 S70 T5
chris k
Post by chris k »
Is there an easy way to tell if the work has already been done? I don't have a check engine light on or anything. I only found the code mentioned on an old diagnostic report from 2008 that was in the car. Just trying to figure out what if anything I need to do before getting an inspection. Thanks for all the help
1996 850 - 138,xxx
jblackburn
Yours went out about the same time mine did, then. That is one of those codes that persistently comes back - so if the light has been off for a few hundred miles it was probably fixed and you should be good to go.
That said, make sure the check engine light lights up when you first flip on the key. I have seen some removed from cars up for sale.
'98 S70 T5
