P0410 Code
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
The relay is mounted right next to the pump and is probably best seen from the underside of the car. To help, it looks quite similar to the fan relay which is mounted above the radiator.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
Did you find the relay? I was told the same thing about it being one of the relays on the fan shroud.Dave123 wrote:Thanks....I'll give it another shot.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- shiloh51933
Yeah it snowed here too and is cold as a mutha right now. When you crawl under you ride it's right under air pump, you have to drop the skid panel down to see it, it looks just like the big relay on the fan shroud but the prongs are a little different.Dave123 wrote:Snowed last night so will have to wait to see where it might be.
vjaneczko
Only one relay on the fan shroud - and it's for the fan.shiloh51933 wrote:Did you find the relay? I was told the same thing about it being one of the relays on the fan shroud.
2006 S60R - For ME!
2006 S60R - For ME!
- shiloh51933
Mine has two and one of them looks just like the sir pump relay. The air pump relay is located right under the air pump itself, drop the front skid plate down, it's the skid plate connected to the front ground effect. n Look on the battery side and you'll see the relay with the air pump right behind it, you can't miss. It will take you all of about five minutes to change it out...taking a tire off is more complicated than changing this relay, lol.vjaneczko wrote:Only one relay on the fan shroud - and it's for the fan.shiloh51933 wrote:Did you find the relay? I was told the same thing about it being one of the relays on the fan shroud.
So here is the deal on my s70. The only wires coming out of the pump are the ones that go to the connector. The connector is located just behind the driver side headlight. I don't have the configuration shown where the relay and ground coming out of the pump are located right next to the pump. So where is the relay? Hate to think that I have to go to a dealer, yikes!!!!
Volvos rock3
- Year and Model: v70xc, 2002
on our 96 the relay was actually zip tied to the pump, the first time the pump threw a code it was for a loose wire in the relay, fixed it 6 months later another code...dead pump (that only runs for less than a 120 seconds upon start up) and it remained that way until we traded it...no performance issues. good luck!
1996 850 GLT sdn (deceased)
2002 V70XC 118k
2009 S80 3.2 37k
1998 Chevrolet K1500 84k
1965 Pontiac Lemans convt
2009 Chevrolet Tahoe PPV 2x (work)
2002 V70XC 118k
2009 S80 3.2 37k
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I'll take a look at my S70 tonight; I did that over 3 years ago and can't remember where the relay is to be honest.
'98 S70 T5
2016 Chevy Cruze Premier
- 25 Replies
- 5907 Views
Last post by Gerd
- 771 Views
- 779 Views
Last post by rnelson1044
- 433 Views
Last post by volvo960sw
- 1044 Views
Last post by benpineapple
