pollen filter
kcv70
- Year and Model: '15 XC70; '12 XC89
- Has thanked: 1 time
2012 XC90 FWD. I changed my cabin air filter this weekend. I'm glad I did this service myself because there were filters in both slots, which is probably not what Volvo intended. The dealer missed this and so did my independent mechanic. I removed the the thinner non-IAQS one and replaced it with the thick Mann CUK 2855 charcoal filter. Thanks to Mann's instructions I realized there are 2 slots.
Jaguar xjs
- Year and Model: 1996 850 turbo
I bought my car about a month ago. There was a musty smell, I know old cars have a certain smell but this was different. The filter must have been the original!
So I removed the filter and started the the car and allowed it to reach operating temp. I then turned the fan on high and turned on the heat. I then sprayed Lysol into the chamber a couple times cycling the knob to run the Lysol through the different vents. I then turned on the AC and sprayed away again. I did this for about an hour, cycling back and forth between AC and heat and position.
Installed a new filter and once the Lysol smell wore off in about and hour, the car smelled nice and fresh with just a hint of old car smell.
Gordon
Gordon
1996 850 turbo
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
- Has thanked: 17 times
- Been thanked: 35 times
Replace at 15K miles...older 850's didn't have them...one of the main causes of the A/C evaporator crapping out.
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
I change mine every fall after the leaves go. I sit in the car with climate control the most in the winter, so it makes sense to me. Plus I put 25,000 miles on my car every year. The $15 on a decent is worth the fresh air. I can definitely tell when it's starting to go.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
btw., does anyone know if the pollen filter assembly out of the 98 up V70 fits the 850? I think so.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 2203 times
Yes it does. I did it on the 97 850 overhaul/project.
All you need to do is to pull the old plastic unit out of the 850 and fit one from a 98-00 S/V 70 with the filter.
I took the opportunity to pull the wiper arms and the cover off from under the windshield area and clean all the accumulated crap out from there and clean out the 4 drain tubes (2 in the air inlet are under the plastic cover and 2 from the plastic cover) and the area around the cold air intake flap. Also took the opportunity to clean and grease the wiper motor and assembly so it ran smoother.
- Clemens
Thanks, Neil!
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Clemens
Btw, I just talked to my Volvo parts guy (he's owned 10 850ies over the years) and said never to use the active charcoal filter because especially on the 850 the blower motor wasn't strong enough and eventually got hot enough to catch fire. Volvo stopped selling them (at least in europe) for that reason.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Been thanked: 4068 times
That sounds like MUSE...made up stuff excrement.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I do them about once a year, usually in the Spring, that works out to about 15,000-20,000 miles for me.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- 961 Views
Last post by FLXC90
- 15 Replies
- 2987 Views
Last post by 454cid
- 1783 Views
Last post by lummert
- 2105 Views
Last post by stephansvolvo
- 15585 Views
Last post by 93Regina
