J-Hose Repair Tutorial w/ pics (EVAP Emission Hose)
This topic is in the MVS Volvo Repair Database » J Hose Repair Tutorial w/ pics -- EVAP Emission Hose
brownfox
Year and Model: 2005 V50 AWD
Post by brownfox »
Does anyone know whether the procedure (remove panel behind right rear seat) works for a 2001 XC70?
Thanks
Xilikon
Year and Model: 2000 V70 XC SE
Post by Xilikon »
pmortv70xc wrote:I did the repair on my 2000 v70 xc by accessing the hose from above through the panel just behind the right rear seat. It was fairly easy.
Thanks, it's helpful. I did see the canister from that hole but didn't check thorougly around if the hoses are accessible as well.
2000 V70 XC SE with 150,000 miles, still going great !
Pauloil
Post by Pauloil »
axlaxl wrote:Thank you so much...I've been dealing with this issue for the past 6 months and have been dreading taking it to the shop to pay for the repair...with this tutorial I am now confident to do it myself...any suggestions on where to get the J hose?
Great job!
the part number at fcpgroton is 9443308
99 V70XC 158K
95 850glt 188K
Mauiman
Year and Model: 1998 V70XC
Post by Mauiman »
My 1998 V70XC, AWD, emissions code 4 (eighth digit in VIN), has the canister on left front behind bumper and in front of tire. Fuel filter, probably fuel pressure regulator and maybe rollover valve are at right rear over and around back axle with access from underside as well as removable access panel below floor inside the car behind the right rear seat (actually there are 2 access panels there above the fuel filter - one is easier to get to than the other).
mtd240
Year and Model: 2007 XC70
Has thanked: 23 times
Been thanked: 7 times
Post by mtd240 »
Mauiman wrote:My 1998 V70XC, AWD, emissions code 4 (eighth digit in VIN), has the canister on left front behind bumper and in front of tire. Fuel filter, probably fuel pressure regulator and maybe rollover valve are at right rear over and around back axle with access from underside as well as removable access panel below floor inside the car behind the right rear seat (actually there are 2 access panels there above the fuel filter - one is easier to get to than the other).
Does this mean there is no "J-hose"?
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it :lol:
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
I'm not sure if it is called a J hose, but there's something very J hoseish on top. I have a 98 AWD. I removed the driver's side corner light fixture and could then see and feel around the top of the canister. One of my hoses was badly cracked. I cracked it off completely, removed the battery and battery tray and was able to wiggle one end of the broken hose through the hole where the battery tray mounts. I had a piece of hard plastic tubing that snugly fit into the broken end of the hose. I inserted about 2 to 3 inches of hose into that broken end and clamped it with a screw type hose clamp. I then fished it back inside, inserted the other end of the plastic tube into the broken remains of the hose on top of the canister. I tried to make both ends of the broken hose sort of straight so that when I put the plastic part into the top of the canister I was then able to wrap it up a bit with electrical tape to hold it in place. A real jury rig I admit and done with about 95% feel but it is working and my EVAP went READY.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
enotslim
Year and Model: 2004 XC70
Has thanked: 71 times
Been thanked: 16 times
Post by enotslim »
Does anyone know the designation of the "other" hose (not the "J" hose) that runs from the shut off valve rearward and connects to a solid pipe? See photos with a great crack in this "L" hose. Clearly needs replacing but I cannot find it anywhere. fcpeuro shows part 9443309 that looks like it might be right, but the description says it runs from the shut off valve to the evap canister. This definitely is not the connection I see on my car.
This is for 1998 V70 T5 wagon
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
Has thanked: 1610 times
Been thanked: 4068 times
Try going to the Lisle Volvo parts site for the exploded diagram with part numbers..
This is what I found, but you need to put YOUR VIN in to get the right parts
Screen Shot 2017-06-06 at 11.49.21 AM.png (184.17 KiB) Viewed 2209 times
enotslim
Post by enotslim »
Thanks. Looks like a good site. But entering the VIN doesn't lead anywhere. I also get a message that the vin is not valid at this site: https://www.volvotechinfo.com/index.cfm ... vindecoder . However, I've given this vin to the dealer and they are able use it to identify parts. No idea what is wrong with my vin. Is it 17 characters, begins with YVILW, etc.
Selecting by year, model, etc. yields a figure like the one you showed. I can't make any sense out of it. For example only one hose is shown connecting to the shut off valve when my car clearly has two. This might be due to a searching for a different model but seems unlikely since they are pretty similar and this is a pretty major difference.
I must be misinterpreting everything.
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
Have you got your Ones zeros , letter Eyes and ohs sorted right in your VIN/
