LOL, man you can't stop an oil leak with silicone. If you're taking about the turbo return line, there is a little kit you can buy to stop it. Easy fix they tell me.
http://www.ipdusa.com/products/5352/111 ... e-seal-kit
Oil leaks, but only while driving
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Thank you; yes: the turbo oil return line.
Let me ask: why's it leak in the first place? I'd think that the oil would just run right into the oil pan, even without a seal; even if the oil returns under pressure, it has the entire oil pan into which to run, right? Seems like it would have to "run uphill" and past the seal, in order to get outside.
Also, what could be used to supplement the seal, if not silicone?
Thanks for the input!
- Been thanked: 504 times
I had the exact same leak, but the Root Cause was the REAR Cam Seal, not the rectangular plate seals as mentioned by rspi.rspi wrote: 12 Jan 2012, 17:22 I had all kinds of oil coming from the back of the S70 motor and found a small access panel leaking. Oil was blowing everywhere. The kit cost about $8 from the stealer, maybe less at yours. Easy fix but hard to find.
Anyway, I updated the seal using Corteco seal ($6/each):
viewtopic.php?t=50752
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Any idea what those locations were purposed for that have blocking plates? Inquiring minds want to know...
2023 Lexus RZ450e -66k
- Has thanked: 1613 times
- Been thanked: 4075 times
Robert...can You post the part number for the block off plate seal kit?
I’m interested.
Wcm...my files Tell be that behind those plates are the toggle switches to enable the heated rear third seat option.
I’m interested.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
I think i would like to have a look at those "Files".abscate wrote: 30 Jan 2018, 07:51 Wcm...my files Tell be that behind those plates are the toggle switches to enable the heated rear third seat option.
