S70 T5 Engine mounts?
This topic is in the MVS Volvo Repair Database » Diagnosing Bad Engine Mounts
fields 100
Year and Model: s 60 T-5 2013
Re: S70 T5 Engine mounts?
Post by fields 100 »
rspi wrote:Age is the #1 cause of rubber failure. So you can have 20,000 miles, hit one good bump and blow a mount.
I totally agree .It HAD to be bad or dried out after so many years. That is what I was hoping for. However,upon inspection, the mount appears to be as good as new - not sagged and pliable,exactly as per your picture.
P.S. Thanks for the nice photos.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
@ Bruce: That looks like the right mount, just made wrong. If you look at the part that goes into the slot on the motor, it's off the amount you say. That's the problem with these companies that decide to "get in the game".
Please let us know where you got the mount so we can steer clear.
Reinie
Year and Model: 1999 S70
Post by Reinie »
I have a 1999 S70 non-turbo with a deep vibration at idle when in "Drive" with the brake applied. The vibration goes away when in park. I inspected the lower right motor mount and it looks okay. Should I attempt to replace it anyway. Its my best guess.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
I would suspect that mount too. It may look OK, but it's hard to tell unless you start jacking up the oil pan (please use a piece of wood under the pan). Then you might see the rubber is separated.
'98 S70 T5
2016 Chevy Cruze Premier
clifford06
Year and Model: 2000 T5
Has thanked: 6 times
Been thanked: 4 times
Post by clifford06 »
Hello. I was having the same vibe problems . Replaced mine Saturday in about 30 min. $32.00 from NAPA. It stopped the vibrations. My car runs smoother, and seems faster. Old one was split on the bottom , out of view. Couldn't pass up for price .
rspi
Post by rspi »
This thread has lots of photos of the mount. If you look at it from the back side you can see if it is flat and resting on the frame.
http://atthetipwebs.com/technologyinstr ... _right.htm
rspi
Post by rspi »
Mount Inspection video.
rspi
Post by rspi »
Reinie
Post by Reinie »
Replaced the lower right engine mount. No improvement. Still a deep vibration at idle when in "drive". I have inspected the transmission mount, which looks okay. Exhaust system has no leakage. I'm thinking it might be something internal with the muffler.
