Where to buy 40 Torx 7" extension bit (Thermostat job)?
- Has thanked: 1611 times
- Been thanked: 4072 times
Am I missing something ? Why don't you put a 1/4 inch extender on a standard T 40 bit?
burnout8488
- Year and Model: 1999 S70 AWD
Is this for the entire thermostat housing or just the neck that the upper radiator hose connects to??
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
- Has thanked: 311 times
- Been thanked: 818 times
The bulky housing around the T 40 bit won't fit, the space is limited. Try it.abscate wrote:Am I missing something ? Why don't you put a 1/4 inch extender on a standard T 40 bit?
It's technically the cover on the housing. The two bolts you access from putting the bit straight down. To take out the thermostat. Ah I see what you're saying - yes, the neck is what everyone is talking about.burnout8488 wrote:Is this for the entire thermostat housing or just the neck that the upper radiator hose connects to??
Keep in mind this is a 10 year old thread, just got bumped ...
Older car, not clear from the OP exactly what year/model
Standard but works fine on my 1999 V70 T5
Thanks for the thread age warning Erik
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I always use the standard bit with an extension without any problem.
- Been thanked: 504 times
Advance Auto Parts sells the Torx set for $10 (the long L-shaped Torx set).
Detail below:
---> https://www.matthewsvolvosite.com/forums ... hp?t=50745
Detail below:
- 20 Replies
- 12401 Views
Last post by erikv11
- 1497 Views
- 14 Replies
- 1726 Views
Last post by Krons
- 2087 Views
Last post by iRenaissanceMan
- 16 Replies
- 3464 Views
Last post by Botbasher
